Where do I post a bug for the ZWaveJS add-on?
This morning, all of my Zwave devices died after upgrading HA OS to 8.5. Rolling back to 8.4 did not resolve the issue neither did any of the following:
  • Swapping the Zwave stick to another USB port
  • Rebooting the host
  • Restarting Core
  • Downgrading from 2022.8.6 to 8.5
  • Restarting ZWaveJS (multiple times)
This is happening and I no matter what I do, I can’t get it to work.
2022-08-23T22:53:52.105Z CNTRLR   finding SUC...
2022-08-23T22:53:52.113Z CNTRLR   This is the SUC
2022-08-23T22:53:52.113Z CNTRLR   querying additional controller information...
2022-08-23T22:53:52.223Z CNTRLR   received additional controller information:
                                    Z-Wave API version:         5 (legacy)
                                    Z-Wave chip type:           ZW050x
                                    node type                   Controller
                                    controller role:            primary
                                    controller is the SIS:      true
                                    controller supports timers: false
                                    nodes in the network:       1
2022-08-23T22:53:52.323Z CNTRLR   [Node 001] Embedded device config loaded
2022-08-23T22:53:52.328Z CNTRLR   setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2022-08-23T22:53:52.334Z CNTRLR   serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
                                  0 ms
2022-08-23T22:53:52.334Z CNTRLR   Interview completed
Starting server on 0.0.0.0:3000
2022-08-23T22:53:52.342Z CNTRLR   [Node 001] The node is alive.
2022-08-23T22:53:52.343Z CNTRLR   [Node 001] The node is ready to be used
2022-08-23T22:53:52.343Z CNTRLR   All nodes are ready to be used
ZwaveJS server listening on 0.0.0.0:3000
New client
2022-08-23T22:53:53.767Z DRIVER   Dropping message because the driver is not ready to handle it yet.
2022-08-23T22:53:53.861Z DRIVER   Dropping message because the driver is not ready to handle it yet.
2022-08-23T22:53:53.961Z DRIVER   Dropping message because the driver is not ready to handle it yet.
2022-08-23T22:53:54.061Z DRIVER   Dropping message because the driver is not ready to handle it yet.
Logger: homeassistant.config_entries
Source: config_entries.py:1031
First occurred: 3:12:14 PM (1 occurrences)
Last logged: 3:12:14 PM
Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Failed to connect: Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed ('172.30.33.2', 3000)]; Retrying in background
You can report issues here:
