Where is Devices.yaml
Hi.
I have the zigbee2mqtt integration working with some aqara zigbee devices. I am trying to use these devices to show temperatures… However, the reading is way to high.
I have found numerous posts noting a variation can be applied within devices.yaml. I cannot for the life of me find devices.yaml. it does not show in my file editor.
Anyone know?
Thanks in advance.,
That file doesn’t exist so I’m not sure where you are getting your info from.
you likely need to create a template sensor to try to correct the value of the readings of the original sensor.
