I am not able to setup and update my Nabu Casa in the Home Assistant after my update to OS 7.0.
Anyone know how to setup the Nabu Casa URL to my Home Assistant? After my last update it is missing from the GUI.
The link to home assistant cloud does not work. Here is the error:
This redirect is not supported by your Home Assistant instance. You need the integration cloud to use this redirect.
I can access to my local HA just fine. But the screen under configuration to setup the cloud Nabu Casa is not longer there. I am not able to find it any where on the new update HA v7.
I cleared my browser cache and restart the home assistant. The Home Assistant Cloud option still not available under the Configuration tab. I am update by restoring from last version of backup. I do have Nabu Casa subscription active. Any idea how to get it back? Or do I have to do a full install without restore from backup?
Please check the home assistant log. Are there any error messages?
I also cannot find the Cloud option after upgrading. I see no messages in the log.
Please advise
Add me to the list, not seeing the option for the paid Nabu Casa subscription. It seems to have not updated my IP address after I lost power for several hours.
I see update version core-2021.12.3 today and updated it. The Home Assistant Cloud option still not available. How do I contact the Home Assistant creator regarding this issue?
Now the only way to get it back is to fresh install without any restore from backup files.
I have the same issue
For those who are still having issues finding the Home Assistant Cloud settings, try adding
cloud:
to your configuration.yaml file. It worked for me. Now the settings are on the main menu, above “Devices & Services”.
There is a bug on the update. I already try that by adding cloud:. Actually the default_config: should works also but not. I just reinstalled HA from new version and add all the devices. I even try using the restore from last version, the cloud still missing. I reinstall the HA and do all the integrations and copy the yaml and automation and now it works…
Adding cloud: in config.yaml and restarting worked for me in HA core-2021.12.9
