Nick24
April 7, 2023, 3:04am
1
I consider myself as beginner in ESPHOME. May I know where to add the additional sensor component(like uptime sensor & wifi signal sensor) in ESPHOME, I try to add by click the edit button at the bluetooth proxy then install but will come out error when compile.
inside the esp32-proxy1.yaml is as below
substitutions:
packages:
esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/esp32-generic.yaml@main
esphome:
name_add_mac_suffix: false
api:
encryption:
key: xxx
wifi:
ssid: !secret wifi_ssid
# sensor:
# - platform: wifi_signal
# name: "WiFi Signal Sensor"
# update_interval: 60s
- platform: uptime
after save & press install, it will come out error below
INFO Reading configuration /config/esphome/esp32-proxy1.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esp32-proxy1 (board: esp32dev; framework: espidf; platform: platformio/espressif32 @ 5.3.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.40404.0 (4.4.4)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.7.1
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
|-- Improv @ 1.2.3
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_frame_helper.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_pb2.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_pb2_service.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_server.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/list_entities.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/proto.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/subscribe_state.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/user_services.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/bluetooth_proxy/bluetooth_connection.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/bluetooth_proxy/bluetooth_proxy.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/button/button.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32/gpio.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32/preferences.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32_ble/ble.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32_ble/ble_advertising.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32_ble/ble_uuid.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32_ble_client/ble_characteristic.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32_ble_client/ble_client_base.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32_ble_client/ble_service.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/esp32_ble_tracker/esp32_ble_tracker.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/improv_base/improv_base.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/improv_serial/improv_serial_component.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/logger/logger.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/md5/md5.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/mdns/mdns_component.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/mdns/mdns_esp32.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/mdns/mdns_esp8266.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/mdns/mdns_rp2040.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/network/util.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/ota/ota_backend_arduino_esp32.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/ota/ota_backend_arduino_esp8266.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/ota/ota_backend_arduino_rp2040.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/ota/ota_backend_esp_idf.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/ota/ota_component.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/safe_mode/button/safe_mode_button.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/socket/bsd_sockets_impl.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/socket/lwip_raw_tcp_impl.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/socket/socket.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/wifi/wifi_component.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/wifi/wifi_component_esp32_arduino.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/wifi/wifi_component_esp8266.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/wifi/wifi_component_esp_idf.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/wifi/wifi_component_pico_w.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/application.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/component.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/component_iterator.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/controller.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/helpers.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/log.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/scheduler.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/util.o
Compiling /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o
Linking /data/esp32-proxy1/.pioenvs/esp32-proxy1/firmware.elf
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection17send_sensor_stateEPNS_6sensor6SensorEf+0x8): undefined reference to `esphome::sensor::Sensor::has_state() const'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection16send_sensor_infoEPNS_6sensor6SensorE+0x10): undefined reference to `esphome::sensor::Sensor::get_unit_of_measurement[abi:cxx11]()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection16send_sensor_infoEPNS_6sensor6SensorE+0x14): undefined reference to `esphome::sensor::Sensor::get_accuracy_decimals()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection16send_sensor_infoEPNS_6sensor6SensorE+0x18): undefined reference to `esphome::sensor::Sensor::get_device_class[abi:cxx11]()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection16send_sensor_infoEPNS_6sensor6SensorE+0x1c): undefined reference to `esphome::sensor::Sensor::get_state_class()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o: in function `esphome::api::APIConnection::send_sensor_state(esphome::sensor::Sensor*, float)':
/config/esphome/.esphome/build/esp32-proxy1/src/esphome/components/api/api_connection.cpp:414: undefined reference to `esphome::sensor::Sensor::has_state() const'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o: in function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::assign(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/data/cache/platformio/packages/[email protected] +2021r2-patch5/xtensa-esp32-elf/include/c++/8.4.0/bits/basic_string.h:1366: undefined reference to `esphome::sensor::Sensor::get_unit_of_measurement[abi:cxx11]()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/api/api_connection.o: in function `esphome::api::APIConnection::send_sensor_info(esphome::sensor::Sensor*)':
/config/esphome/.esphome/build/esp32-proxy1/src/esphome/components/api/api_connection.cpp:426: undefined reference to `esphome::sensor::Sensor::get_accuracy_decimals()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-proxy1/src/esphome/components/api/api_connection.cpp:427: undefined reference to `esphome::sensor::Sensor::get_device_class[abi:cxx11]()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-proxy1/src/esphome/components/api/api_connection.cpp:429: undefined reference to `esphome::sensor::Sensor::get_state_class()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o:(.literal._Z5setupv+0xb8): undefined reference to `vtable for esphome::uptime::UptimeSensor'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o:(.literal._Z5setupv+0xbc): undefined reference to `vtable for esphome::uptime::UptimeSensor'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o:(.literal._Z5setupv+0x108): undefined reference to `esphome::sensor::Sensor::Sensor()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o:(.literal._Z5setupv+0x10c): undefined reference to `esphome::sensor::Sensor::set_device_class(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o:(.literal._Z5setupv+0x110): undefined reference to `esphome::sensor::Sensor::set_state_class(esphome::sensor::StateClass)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o:(.literal._Z5setupv+0x114): undefined reference to `esphome::sensor::Sensor::set_unit_of_measurement(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o:(.literal._Z5setupv+0x118): undefined reference to `esphome::sensor::Sensor::set_accuracy_decimals(signed char)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o: in function `esphome::safe_mode::SafeModeButton::SafeModeButton()':
/config/esphome/.esphome/build/esp32-proxy1/src/esphome/components/safe_mode/button/safe_mode_button.h:10: undefined reference to `esphome::sensor::Sensor::Sensor()'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o: in function `setup()':
/config/esphome/.esphome/build/esp32-proxy1/src/main.cpp:218: undefined reference to `esphome::sensor::Sensor::set_device_class(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o: in function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()':
/data/cache/platformio/packages/[email protected] +2021r2-patch5/xtensa-esp32-elf/include/c++/8.4.0/bits/basic_string.h:657: undefined reference to `esphome::sensor::Sensor::set_state_class(esphome::sensor::StateClass)'
/config/esphome/.esphome/build/esp32-proxy1/src/main.cpp:233: undefined reference to `esphome::sensor::Sensor::set_unit_of_measurement(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/main.o: in function `esphome::uptime::UptimeSensor::UptimeSensor()':
/config/esphome/.esphome/build/esp32-proxy1/src/esphome/components/uptime/uptime_sensor.h:9: undefined reference to `esphome::sensor::Sensor::set_accuracy_decimals(signed char)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/controller.o:(.literal._ZN7esphome10Controller16setup_controllerEb+0x8): undefined reference to `esphome::sensor::Sensor::add_on_state_callback(std::function<void (float)>&&)'
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/core/controller.o: in function `esphome::Controller::setup_controller(bool)':
/config/esphome/.esphome/build/esp32-proxy1/src/esphome/core/controller.cpp:29: undefined reference to `esphome::sensor::Sensor::add_on_state_callback(std::function<void (float)>&&)'
collect2: error: ld returned 1 exit status
*** [/data/esp32-proxy1/.pioenvs/esp32-proxy1/firmware.elf] Error 1
========================= [FAILED] Took 21.20 seconds =========================
I believe I might add the sensor component to wrong place or wrong indentation.
nickrout
(Nick Rout)
April 7, 2023, 3:35am
2
Your config looks correct. What version of esphome are you using?
Troon
(Troon)
April 7, 2023, 7:57am
4
I could be wrong, but I think this is due to the indentation of the end of the package file you’re importing: bluetooth-proxies/esp32-generic.yaml at 6ccc74c87fc658dc1ba56bec1771aea4a9f86a6b · esphome/bluetooth-proxies · GitHub
The first sign of an error in the compilation logs is a reference to “Sensor” within safe_mode_button.
Maybe try copy/pasting the config out of that package into your code, then removing the packages declaration? Like this:
substitutions:
friendly_name: Bluetooth Proxy
esp32:
board: esp32dev
framework:
type: esp-idf
esphome:
friendly_name: ${friendly_name}
project:
version: "1.0"
api:
encryption:
key: xxx
wifi:
ap:
logger:
ota:
improv_serial:
dashboard_import:
package_import_url: github://esphome/bluetooth-proxies/esp32-generic.yaml@main
esp32_ble_tracker:
scan_parameters:
# We currently use the defaults to ensure Bluetooth
# can co-exist with WiFi In the future we may be able to
# enable the built-in coexistence logic in ESP-IDF
active: true
bluetooth_proxy:
active: true
button:
- platform: safe_mode
name: Safe Mode Boot
entity_category: diagnostic
# sensor:
- platform: uptime
Nick24
April 7, 2023, 8:12am
5
@Troon , somehow with the default setting, without the wifi signal & uptime sensor, the install work. HA did detect the safe mode button.
Below with the default yaml without adding any extra sensor to it & compile successfully
Dependency Graph
|-- noise-c @ 0.1.4
|-- Improv @ 1.2.3
RAM: [== ] 16.4% (used 53784 bytes from 327680 bytes)
Flash: [======= ] 69.8% (used 1280929 bytes from 1835008 bytes)
Building /data/esp32-proxy1/.pioenvs/esp32-proxy1/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin(["/data/esp32-proxy1/.pioenvs/esp32-proxy1/firmware.bin"], ["/data/esp32-proxy1/.pioenvs/esp32-proxy1/firmware.elf"])
Wrote 0x14a210 bytes to file /data/esp32-proxy1/.pioenvs/esp32-proxy1/firmware-factory.bin, ready to flash to offset 0x0
========================= [SUCCESS] Took 20.84 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of esp32-proxy1.local
INFO -> x
INFO Uploading /data/esp32-proxy1/.pioenvs/esp32-proxy1/firmware.bin (1286672 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from esp32-proxy1.local using esphome API
INFO Successfully connected to esp32-proxy1.local
[16:42:53][I][app:102]: ESPHome version 2023.3.2 compiled on Apr 7 2023, 16:42:18
[16:42:53][I][app:104]: Project esphome.bluetooth-proxy version 1.0
[16:42:53][C][wifi:504]: WiFi:
[16:42:53][C][wifi:362]: Local MAC: x
[16:42:53][C][wifi:363]: SSID: 'x'[redacted]
[16:42:53][C][wifi:364]: IP Address: x
[16:42:53][C][wifi:366]: BSSID: x[redacted]
[16:42:53][C][wifi:367]: Hostname: 'esp32-proxy1'
[16:42:53][C][wifi:369]: Signal strength: -70 dB ▂▄▆█
[16:42:53][C][wifi:373]: Channel: 1
[16:42:53][C][wifi:374]: Subnet: 255.255.255.0
[16:42:53][C][wifi:375]: Gateway: x
[16:42:53][C][wifi:376]: DNS1: x
[16:42:53][C][wifi:377]: DNS2: x
[16:42:53][C][logger:293]: Logger:
[16:42:53][C][logger:294]: Level: DEBUG
[16:42:53][C][logger:295]: Log Baud Rate: 115200
[16:42:53][C][logger:296]: Hardware UART: UART0
[16:42:53][C][bluetooth_proxy:065]: Bluetooth Proxy:
[16:42:53][C][bluetooth_proxy:066]: Active: YES
[16:42:53][C][safe_mode.button:022]: Safe Mode Button 'Safe Mode Boot'
[16:42:53][C][safe_mode.button:022]: Icon: 'mdi:restart-alert'
[16:42:53][C][esp32_ble:214]: ESP32 BLE:
[16:42:53][C][esp32_ble_tracker:591]: BLE Tracker:
[16:42:53][C][esp32_ble_tracker:592]: Scan Duration: 300 s
[16:42:53][C][esp32_ble_tracker:593]: Scan Interval: 320.0 ms
[16:42:53][C][esp32_ble_tracker:594]: Scan Window: 30.0 ms
[16:42:53][C][esp32_ble_tracker:595]: Scan Type: ACTIVE
[16:42:53][C][esp32_ble_tracker:596]: Continuous Scanning: True
[16:42:53][C][mdns:108]: mDNS:
[16:42:53][C][mdns:109]: Hostname: esp32-proxy1
[16:42:53][C][ota:093]: Over-The-Air Updates:
[16:42:53][C][ota:094]: Address: esp32-proxy1.local:3232
[16:42:53][C][api:138]: API Server:
[16:42:53][C][api:139]: Address: esp32-proxy1.local:6053
[16:42:53][C][api:141]: Using noise encryption: YES
[16:42:53][C][improv_serial:032]: Improv Serial:
Troon
(Troon)
April 7, 2023, 9:05am
6
Right, and what does the config I created above do?
Nick24
April 7, 2023, 9:10am
7
your config direct come out error below after click install
Failed config
button.safe_mode: [source /config/esphome/esp32-proxy1.yaml:37]
Component button.safe_mode requires component ota.
platform: safe_mode
Troon
(Troon)
April 7, 2023, 9:14am
8
Oops, missed the ota:
line. Edited above: try again?
Nick24
April 7, 2023, 9:18am
9
different error come out this time
Dependency Graph
|-- noise-c @ 0.1.4
|-- Improv @ 1.2.3
*** [/data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/dashboard_import/dashboard_import.o] Source `src/esphome/components/dashboard_import/dashboard_import.cpp' not found, needed by target `/data/esp32-proxy1/.pioenvs/esp32-proxy1/src/esphome/components/dashboard_import/dashboard_import.o'.
========================== [FAILED] Took 5.22 seconds ==========================
Troon
(Troon)
April 7, 2023, 9:19am
10
Sign. Nearly there: one more go? Refresh this page and re-copy it…
Nick24
April 7, 2023, 9:25am
11
this time also different error
Dependency Graph
|-- noise-c @ 0.1.4
|-- Improv @ 1.2.3
========================= [FAILED] Took 20.85 seconds =========================
Troon
(Troon)
April 7, 2023, 9:28am
12
I think that’s pretty much the original error, actually. I’m out of ideas, then: sorry…
Nick24
April 7, 2023, 9:29am
13
is ok. actually not just this version, all previous version also like that, suspect my format could be wrong.
Troon
(Troon)
April 7, 2023, 9:35am
14
Hm, that latest version of mine, and your original, both compile here.
Compiling .pioenvs/esp32-proxy1/bootloader/spi_flash/esp32/spi_flash_rom_patch.o
Archiving .pioenvs/esp32-proxy1/bootloader/esp-idf/soc/libsoc.a
Compiling .pioenvs/esp32-proxy1/bootloader/xtensa/eri.o
Compiling .pioenvs/esp32-proxy1/bootloader/xtensa/xt_trax.o
Archiving .pioenvs/esp32-proxy1/bootloader/esp-idf/xtensa/libxtensa.a
Generating partitions .pioenvs/esp32-proxy1/partitions.bin
Generating an empty partition .pioenvs/esp32-proxy1/ota_data_initial.bin
Compiling .pioenvs/esp32-proxy1/lib2c6/Improv/improv.o
Archiving .pioenvs/esp32-proxy1/bootloader/esp-idf/spi_flash/libspi_flash.a
Linking .pioenvs/esp32-proxy1/bootloader.elf
Building .pioenvs/esp32-proxy1/bootloader.bin
Archiving .pioenvs/esp32-proxy1/lib2c6/libImprov.a
Linking .pioenvs/esp32-proxy1/firmware.elf
RAM: [== ] 16.7% (used 54584 bytes from 327680 bytes)
Flash: [======= ] 65.4% (used 1199525 bytes from 1835008 bytes)
Building .pioenvs/esp32-proxy1/firmware.bin
esp32_create_combined_bin([".pioenvs/esp32-proxy1/firmware.bin"], [".pioenvs/esp32-proxy1/firmware.elf"])
Wrote 0x136430 bytes to file /config/.esphome/build/esp32-proxy1/.pioenvs/esp32-proxy1/firmware-factory.bin, ready to flash to offset 0x0
======================== [SUCCESS] Took 262.24 seconds ========================
That suggests an issue with your installation rather than your YAML config. I’m on 2023.2.4 — I’ll try the latest now.
Troon
(Troon)
April 7, 2023, 9:55am
15
Your original code also compiles without error on the latest Docker container version, 2023.3.2:
RAM: [== ] 16.4% (used 53728 bytes from 327680 bytes)
Flash: [======= ] 66.3% (used 1217137 bytes from 1835008 bytes)
Wrote 0x13a8e0 bytes to file /config/.esphome/build/esp32-proxy1/.pioenvs/esp32-proxy1/firmware-factory.bin, ready to flash to offset 0x0
======================== [SUCCESS] Took 655.60 seconds ========================
nickrout
(Nick Rout)
April 7, 2023, 10:01am
16
@Nick24 are you sure you don’t have weird characters in your yaml file? Like tab characters or screwed up line endings? What are you using to edit the yaml? Where are you cutting and pasting it from?
Nick24
April 10, 2023, 3:08am
18
@nickrout , really strange, I’m using chrome browser to open the home assistant web page. I edit the yaml directly from the home assistant as shown below
I didn’t put any extra tab, should I edit the yaml file using special text editor?
Nick24
April 10, 2023, 3:10am
19
@Troon , u got add the uptime sensor when you compile?
nickrout
(Nick Rout)
April 10, 2023, 3:14am
20
@Nick24 I think you might be running out of RAM. By chance are you compiling on a RPi 3?
Nick24
April 10, 2023, 3:27am
21
@nickrout this HA is running on proxmox & run as ova. I allocate 4Gb to the HA & still have pretty of ram left over as below
