I’ve done a little edit in my dashboards, since the one i edited was a single card dashboard i deleted the whole content with the 3dots on the lower left. No problem, i thought, pressed no save, no done, but it is away.
I checked the RAW Configuration Editor, yes, gone.
Where can i find the code of the individual dashboards in the manual Backup i’ve done?
in a backup-file the path is /supervisor/homeassistant/.storage
I suggest you find the file in “where/how ever” you backed up … And go to this url
and “import file”
Then copy the result, and paste it in a “new created dashboard” in Raw Editor, then save, if it complains, edit … i have tried ones it worked perfectly
PS: Remove the first 5 lines ( Dashboard starts with "view: ) … Don’t mind the “indentations” , just save, and HA should fix this … Unless your Dashboard was screwed up in the first place
