Adding new, first, device via matter wifi with HA on virtualbox via android companion appl and getting the “something went wrong” after passing connectivity established on wifi network and failing/timing out on adding the device to home assistant. I have IPV6 turned on in router and in HA. Again, all the above is using the Android app to add a first and new device.
My deduction is that it is failing during the Operational Discovery phase where HA broadcasts via mDNS to the device and the device is supposed to answer. Again, this is my deduction from the just listed understanding.
Is HA receiving a request to add the device and then mDNS-ing the device or has the device already presented and now asking to be added to HA?
Not sure where to go from here other than to point the finger at the device and say it is not responding - So where do I go from here?
Here are the logs to support my deductions and understandings. There are a several attempts
t2026-08-19 23:04:36.174 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 13 next: 1m 30s
2026-08-19 23:06:06.179 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 14 next: 1m 30s
2026-08-19 23:07:35.265 DEBUG WebSocketC~erHandler [0] WebSocket request {
"message_id": "ea0f3684fff44f0a9dc746da48f60071",
"command": "commission_on_network",
"args": {
"setup_pin_code": 94291964,
"ip_addr": "fe80::5a48:49ff:XXXX:XXXX%47" **SAME V6 add in all msgs
2026-08-19 23:07:35.269 INFO ConfigStorage Set config key nextNodeId to 14
2026-08-19 23:07:35.283 INFO Discovery Initiating discovery of node discovery
2026-08-19 23:07:36.182 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 15 next: 1m 30s
2026-08-19 23:09:06.194 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 16 next: 1m 30s
2026-08-19 23:10:35.296 ERROR WebSocketC~erHandler [0] WebSocket error response (commission_on_network) ea0f3684fff44f0a9dc746da48f60071 Commission failed: discovery of node discovery failed: No commissionable device was discovered
at ServerError.nodeCommissionFailed (/opt/matter-server/node_modules/@matter-server/ws-controller/src/types/WebSocketMessageTypes.ts:107:16)
at ControllerCommandHandler.commissionNode (/opt/matter-server/node_modules/@matter-server/ws-controller/src/controller/ControllerCommandHandler.ts:1245:31)
at async WebSocketControllerHandler.#commissionWithRetry (/opt/matter-server/node_modules/@matter-server/ws-controller/src/server/WebSocketControllerHandler.ts:982:47)
at async WebSocketControllerHandler.#handleCommissionOnNetwork (/opt/matter-server/node_modules/@matter-server/ws-controller/src/server/WebSocketControllerHandler.ts:1092:24)
at async WebSocketControllerHandler.#handleWebSocketRequest (/opt/matter-server/node_modules/@matter-server/ws-controller/src/server/WebSocketControllerHandler.ts:704:30)
Caused by: [discovery] discovery of node discovery failed: No commissionable device was discovered
at CommissioningDiscovery.onComplete (/opt/matter-server/node_modules/@matter/node/src/behavior/system/controller/discovery/ParallelPaseDiscovery.ts:182:19)
2026-08-19 23:10:36.206 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 17 next: 1m 30s
2026-08-19 23:12:06.216 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 18 next: 1m 30s
2026-08-20 19:54:49.546 DEBUG WebSocketC~erHandler [0] WebSocket request {
"message_id": "74d3735bedca4ae38ce710597426ad23",
"args": {
"setup_pin_code": 60810212,
2026-08-20 19:54:49.556 INFO ConfigStorage Set config key nextNodeId to 15
2026-08-20 19:54:49.605 INFO Discovery Initiating discovery of node discovery
2026-08-20 19:55:21.118 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 25 next: 1m 30s
2026-08-20 19:56:51.126 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 26 next: 1m 30s
2026-08-20 19:57:49.606 ERROR WebSocketC~erHandler [0] WebSocket error response (commission_on_network) 74d3735bedca4ae38ce710597426ad23 Commission failed: discovery of node discovery failed: No commissionable device was discovered
at ServerError.nodeCommissionFailed (/app/node_modules/@matter-server/ws-controller/src/types/WebSocketMessageTypes.ts:107:16)
at ControllerCommandHandler.commissionNode (/app/node_modules/@matter-server/ws-controller/src/controller/ControllerCommandHandler.ts:1245:31)
at async WebSocketControllerHandler.#commissionWithRetry (/app/node_modules/@matter-server/ws-controller/src/server/WebSocketControllerHandler.ts:982:47)
at async WebSocketControllerHandler.#handleCommissionOnNetwork (/app/node_modules/@matter-server/ws-controller/src/server/WebSocketControllerHandler.ts:1092:24)
at async WebSocketControllerHandler.#handleWebSocketRequest (/app/node_modules/@matter-server/ws-controller/src/server/WebSocketControllerHandler.ts:704:30)
2026-08-20 20:00:13.136 DEBUG WebSocketC~erHandler [2] WebSocket request {"message_id":"1319882588","command":"get_fabric_label","args":{}}
2026-08-20 20:00:13.137 DEBUG WebSocketC~erHandler [2] WebSocket response (get_fabric_label) 1319882588 { fabric_label: "Home" }
2026-08-20 20:00:16.762 DEBUG WebSocketC~erHandler [2] WebSocket request {"message_id":"1319882589","command":"get_loglevel","args":{}}
2026-08-20 20:00:16.763 DEBUG WebSocketC~erHandler [2] WebSocket response (get_loglevel) 1319882589 { console_loglevel: "debug", file_loglevel: null }
2026-08-20 20:00:16.766 DEBUG WebSocketC~erHandler [2] WebSocket request {"message_id":"1319882590","command":"get_all_credentials","args":{}}
2026-08-20 20:00:16.768 DEBUG WebSocketC~erHandler [2] WebSocket response (get_all_credentials) 1319882590 { wifi: [ { id: "default", ssid: "3o3p" } ], thread: [ { id: "default" } ] }
2026-08-20 20:00:29.134 INFO WebSocketC~erHandler [2] WebSocket connection closed
2026-08-20 20:01:21.178 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 29 next: 1m 30s
2026-08-20 20:02:51.198 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 30 next: 1m 30s
2026-08-20 20:03:50.434 DEBUG WebSocketC~erHandler [0] WebSocket request {
"message_id": "e82d8dab7379440ca768c0ac6d9b2259",
"args": {
"setup_pin_code": 50989060,
2026-08-20 20:03:50.436 INFO ConfigStorage Set config key nextNodeId to 16
2026-08-20 20:03:50.561 INFO Discovery Initiating discovery of node discovery
2026-08-20 20:04:21.204 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 31 next: 1m 30s
2026-08-20 20:05:51.216 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 32 next: 1m 30s
2026-08-20 20:06:50.568 ERROR WebSocketC~erHandler [0] WebSocket error response (commission_on_network) e82d8dab7379440ca768c0ac6d9b2259 Commission failed: discovery of node discovery failed: No commissionable device was discovered
at CommissioningDiscovery.onComplete (/app/node_modules/@matter/node/src/behavior/system/controller/discovery/ParallelPaseDiscovery.ts:182:19)
000000000001B669._matter._tcp.local number: 21 next: 1m 30s
2026-08-20 22:05:20.691 DEBUG WebSocketC~erHandler [0] WebSocket request {
"message_id": "d7a07554989c405f8349d50c5d34bf60",
"args": {
"setup_pin_code": 63370246,
2026-08-20 22:05:20.698 INFO ConfigStorage Set config key nextNodeId to 17
2026-08-20 22:05:20.748 INFO Discovery Initiating discovery of node discovery
2026-08-20 22:06:41.147 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 22 next: 1m 30s
2026-08-20 22:08:11.169 DEBUG MdnsAdvertisement Broadcast kind: operational service: mdns:A9B10300C31BA064-000000000001B669._matter._tcp.local number: 23 next: 1m 30s
2026-08-20 22:08:20.762 ERROR WebSocketC~erHandler [0] WebSocket error response (commission_on_network) d7a07554989c405f8349d50c5d34bf60 Commission failed: discovery of node discovery failed: No commissionable device was discovered
