Sorry if this us a dumb question. Still learning. I want to use this script that I found in a community thread:
alias: Example 1
- platform: time
at:
- '05:00:00'
- '05:15:00'
- platform: homeassistant
event: start
condition: "{{ (now() - as_datetime('19700101T00Z')).days % 2 == 0 }}"
- service: "switch.turn_{{ iif(now().hour == 5 and 0 <= now().minute < 15, 'on', 'off') }}"
entity_id: switch.your_device
Question is, where do I enter this? I’ve looked around the UI under automations and can’t seem to find the right place.
123
(Taras)
2
The automation example you posted looked very familiar to me and then I realized it’s something I had created almost three years ago.
That’s an automation as opposed to a script (two different terms in Home Assistant).
Start Home Assistant’s Automation Editor like this:
- Settings → Automation & scenes → Create Automation → Create new automation
- Click the overflow menu in the upper right corner (three vertical dots) and select Edit in YAML.
- Delete the existing YAML code displayed in the editing window.
- Copy the automation example posted above and paste it into the Automation Editor’s editing window then click Save.
References
Automation
Script
Glossary
(Taras)
4
Did my instructions answer your question regarding where to enter the automation’s YAML code? Or do you require additional assistance?
