Where to run Node-RED?
I’m sure there’s a lot of opinions on this but I’d like to hear some of them.
I’ve been testing HAOS on a Pi400 for the last month or so and I’m now at the point werehe I want to create a VirtualBox VM to run HAOS. My question is where should I run Node-RED? Should I go with the add-on method or in another VM or yet another physical machine? I’m thinking another VM connected to an internal network using a virtual network adapter.
Any guidance is appreciated.
It depends on your usage and available hardware.
In my case, Node-RED isn’t needed if Home Assistant is off (maintenance, etc.). So I use it as an add-on.
Since I have a mini PC running Proxmox, I would create an LXC server if I needed Node-RED running independently of Home Assistant.
Thanks for the suggestion. It’s been a while since I last looked at Proxmox but I thought it had problems with attaching USB devices to VMs. So far I’ll be using a ZWA-2 and a Conbee II, which are both USB.
I need to think about whether or not I need Node-RED to be independent of Home Assistant.
I originally set up NR in a separate VM along with other services that could alternatively be installed as addons (eg MQTT). I did this because it was 2016 and I was concerned about the stability of HA - so paranoia really. I since installed the addon, but have never moved everything across.
The main down-side of having it separate is keeping it (and the OS) up-to-date is slightly harder. I keep thinking there are up-sides, but when I think it through, they’re imaginary. The only real one is you can run more than one, whereas you can only have one addon. So I have a separate NR instance that is unrelated to HA, and another for testing stuff, along with the one where my automations live. But really only because I can.
But the real message is - don’t use VirtualBox, use Proxmox.
Thanks Michael. I appreciate your reply.
For the near-term, I’m stuck with Virtualbox since this will be running on the same win10Pro system that is also running HomeSeer HS4. That being said, I already have an NR instance as well as MQTT, InfluxDB, and Grafana running on a separate system, so I’m just going to utilize that for now until I can acquire some new hardware that is Proxmox capable.
One thing, have you had any issues with USB devices with Proxmox?
I’ve been running HA under Proxmox for several years now and have never experienced any issues with USB devices. My Z-Wave USB controller works just fine.
Thanks for confirming. For those reading this later the official name is “Proxmox USB Passthrough” which allows USB devices to be connected directly to a VM.
My two cents, ditch VB and use Vmware Workstation. A bit harder to install, but much more reliable as VB (which has a lot of ram/cpu issues every time I tried to run it)
PS: Workstation is nowadays free to run for personal use :grin:
Thanks for the input. TBH, I’m very comfortable with Virtualbox so I’m going to go with that for the short-term. Long-term it appears that Proxmox is the way to go for me but it will likely be a few months out before I get the new hardware.
