Which docker image is best for QNAP NAS TS-431X2 running ArmV7-a?
I’ve tried armhf-homeassistant stable and it runs with JEMALLOC disabled but it’s 2021 and missing loads of features, I tried 2023.1.1 but it loops on startup with:
[18:04:50] INFO: Home Assistant Core finish process exit code 256
[18:04:50] INFO: Home Assistant Core finish process received signal 11
[18:04:51] INFO: Home Assistant Core finish process exit code 256
[18:04:51] INFO: Home Assistant Core finish process received signal 11
I’ve tried 2025.2.5 but it does not run at all and produces no logs.
I’ve tried homeassistant/armv7-homeassistant-base:2023.05.0 but that doesn’t run either.
I’ve looked at various threads on here and on github including this one:
armv7 QNAP Docker: Restarting loop - Core finish process exit code 256 - Core finish process received signal 11 (exit code 139 and exit code 135) · Issue #86589 · home-assistant/core · GitHub) but that one didn’t seem to get resolved without alot of expertise and having to build packages on the device.
Does anyone have any advice?
Many thanks.
