Where is the configuration file configuration.yaml and customize.yaml of HomeAssistant?
I can’t find it with the find command.
/config/configuration.yaml
/config/customize.yaml
It depends how you instaled home assistant. There are four methods, it is specisifed under Configuration/Info in the GUI. eg mine says
Installation Type Home Assistant Supervised
Thank you very much, I will read it carefully.
Yes I think you’re right, thank you very much for your help!
Thank you so much for your reply and help!
