I have HA running on a dedicated mini PC which could be moved to a more central location, it’s currently in my office at the end of the garden.
Currently I have everything I need running via unify (cameras), hive and my Yale alarm. I’ve been playing with some automation but using the hive door sensors to run some automation is slow, therefore I need better door contacts.
I picked up some Ikea contacts yesterday but not I need a Matter coordinator.
I’ve looked at the ZBT-2 but then the SMLIGHT stuff looks great as I could just but that where I wanted using POE. But I’m lost since there are so many options.
I’ve come across Aliexpress but then which one? SLZB-MR3U?
On Aliexpress, are these legit devices or should I be buying from the UK/Europe?
I bought the SLZB-06Mg26 because I only use Zigbee. If you want to use Zigbee and Matter, you should read up on the issues of running both protocols on a single coordinator.
I’m not using Matter so can’t recommend a suitable coordinator. There are plenty of threads on here with users complaining about something to do with Matter. I’m not across the details though.
Is there a reason you are wedded to Matter? My Zigbee mesh has a 102 devices (mostly routers) and works very well.
I have a few days newest SLZB-MR5U and it looks very good. New chips, highest number of devices, but fully supported in dev branch of HA only, currently I have such 150 Zigbee and 10 Thread devices, Z-wave still not tested, I have old stick in HA Usb port with one device. Moved from deconz II and ZBT1. Many different devices, Ikea, Tuya etc.
