While scanning for the next token found character '%' that cannot start any token in "/config/automations.yaml",
I’m getting the follow error
  • while scanning for the next token found character ‘%’ that cannot start any token in “/config/automations.yaml”, line 10, column 8 for the yaml below.
- alias: 'Smart button front door'
    - platform: state
      entity_id: input_boolean.front_door_tap
      to: 'on'
    - service: >
      {%- for light in states.light %}
      {%- if is_state(light.entity_id, 'on') %}
        {{light.entity_id}}.turn_off
      {%- endif %}
     {%-endfor%}
what am i doing wrong?
your indentation is off:
    - platform: state
      to: 'on'
    - service: >
          {%- endif %}
       {%-endfor%}
However the template won’t work the way you are trying to use it.
Ever action needs a service call. In your case you want to turn off lights that are on.
so you need to call the light.turn_off service. but the light.turn_off service needs an entity_id (or multiple)
so in it’s basic for it looks like this:
- service: light.turn_off
  entity_id: light.some_light
what you will end up with when the template is rendered on the first light that’s on is:
- service: some_light.turn_off
which won’t work.
hopefully you see the difference.
