Would be possible to add 2 new sensors for climate, like Current temperature and Current Humidity, i am using something like custom right now but to be added to the official integration would be even better.
Please have a look on the code and if you think that can be added would be grate.
“”“Platform for Whirlpool sensors (washer/dryer and now aircon).”“”
from future import annotations
import logging
from collections.abc import Callable
from dataclasses import dataclass
from datetime import datetime, timedelta
from typing import Any
from whirlpool.aircon import Aircon
from whirlpool.washerdryer import MachineState, WasherDryer
from homeassistant.components.sensor import (
RestoreSensor,
SensorDeviceClass,
SensorEntity,
SensorEntityDescription,
SensorStateClass,
from homeassistant.const import UnitOfTemperature, PERCENTAGE
from homeassistant.core import HomeAssistant, callback
from homeassistant.helpers.device_registry import DeviceInfo
from homeassistant.helpers.entity_platform import AddConfigEntryEntitiesCallback
from homeassistant.helpers.typing import StateType
from homeassistant.util.dt import utcnow
from . import WhirlpoolConfigEntry
from .const import DOMAIN
_LOGGER = logging.getLogger(name)
Washer/Dryer Sensors (unchanged from official code, except reorganized for clarity)
TANK_FILL = {
“0”: “unknown”,
“1”: “empty”,
“2”: “25”,
“3”: “50”,
“4”: “100”,
“5”: “active”,
MACHINE_STATE = {
MachineState.Standby: “standby”,
MachineState.Setting: “setting”,
MachineState.DelayCountdownMode: “delay_countdown”,
MachineState.DelayPause: “delay_paused”,
MachineState.SmartDelay: “smart_delay”,
MachineState.SmartGridPause: “smart_grid_pause”,
MachineState.Pause: “pause”,
MachineState.RunningMainCycle: “running_maincycle”,
MachineState.RunningPostCycle: “running_postcycle”,
MachineState.Exceptions: “exception”,
MachineState.Complete: “complete”,
MachineState.PowerFailure: “power_failure”,
MachineState.ServiceDiagnostic: “service_diagnostic_mode”,
MachineState.FactoryDiagnostic: “factory_diagnostic_mode”,
MachineState.LifeTest: “life_test”,
MachineState.CustomerFocusMode: “customer_focus_mode”,
MachineState.DemoMode: “demo_mode”,
MachineState.HardStopOrError: “hard_stop_or_error”,
MachineState.SystemInit: “system_initialize”,
def washer_state(washer: WasherDryer) → str | None:
“”“Determine correct states for a washer/dryer.”“”
DOOR_OPEN = “door_open”
if washer.get_attribute("Cavity_OpStatusDoorOpen") == "1":
return DOOR_OPEN
machine_state = washer.get_machine_state()
CYCLE_FUNC = [
(WasherDryer.get_cycle_status_filling, "cycle_filling"),
(WasherDryer.get_cycle_status_rinsing, "cycle_rinsing"),
(WasherDryer.get_cycle_status_sensing, "cycle_sensing"),
(WasherDryer.get_cycle_status_soaking, "cycle_soaking"),
(WasherDryer.get_cycle_status_spinning, "cycle_spinning"),
(WasherDryer.get_cycle_status_washing, "cycle_washing"),
if machine_state == MachineState.RunningMainCycle:
for func, cycle_name in CYCLE_FUNC:
if func(washer):
return cycle_name
return MACHINE_STATE.get(machine_state)
@dataclass(frozen=True, kw_only=True)
class WhirlpoolSensorEntityDescription(SensorEntityDescription):
“”“Describes Whirlpool Washer/Dryer sensor entity.”“”
value_fn: Callable
SENSORS: tuple[WhirlpoolSensorEntityDescription, …] = (
key=“state”,
translation_key=“whirlpool_machine”,
device_class=SensorDeviceClass.ENUM,
options=(
list(MACHINE_STATE.values())
+ [“cycle_filling”, “cycle_rinsing”, “cycle_sensing”, “cycle_soaking”,
“cycle_spinning”, “cycle_washing”, “door_open”]
value_fn=washer_state,
key=“DispenseLevel”,
translation_key=“whirlpool_tank”,
entity_registry_enabled_default=False,
options=list(TANK_FILL.values()),
value_fn=lambda wd: TANK_FILL.get(
wd.get_attribute(“WashCavity_OpStatusBulkDispense1Level”)
Washer/dryer time sensor
SENSOR_TIMER: tuple[SensorEntityDescription] = (
key=“timeremaining”,
translation_key=“end_time”,
device_class=SensorDeviceClass.TIMESTAMP,
class WasherDryerClass(SensorEntity):
“”“A sensor entity for Whirlpool washers/dryers.”“”
_attr_should_poll = False
_attr_has_entity_name = True
def __init__(
self,
washer_dryer: WasherDryer,
description: WhirlpoolSensorEntityDescription
) -> None:
"""Initialize the washer sensor."""
self._wd: WasherDryer = washer_dryer
self.entity_description = description
# Icon
if washer_dryer.name == "dryer":
self._attr_icon = "mdi:tumble-dryer"
else:
self._attr_icon = "mdi:washing-machine"
self._attr_device_info = DeviceInfo(
identifiers={(DOMAIN, washer_dryer.said)},
name=washer_dryer.name.capitalize(),
manufacturer="Whirlpool",
self._attr_unique_id = f"{washer_dryer.said}-{description.key}"
async def async_added_to_hass(self) -> None:
"""Register updates callback."""
self._wd.register_attr_callback(self.async_write_ha_state)
async def async_will_remove_from_hass(self) -> None:
"""Unregister updates callback."""
self._wd.unregister_attr_callback(self.async_write_ha_state)
@property
def available(self) -> bool:
"""Return True if online."""
return self._wd.get_online()
@property
def native_value(self) -> StateType | str:
"""Return the sensor value."""
return self.entity_description.value_fn(self._wd)
class WasherDryerTimeClass(RestoreSensor):
“”“A timestamp sensor for Whirlpool washers/dryers (cycle end time).”“”
_attr_should_poll = True
def __init__(self, washer_dryer: WasherDryer, description: SensorEntityDescription) -> None:
"""Initialize the washer time sensor."""
self._running: bool | None = None
else:
"""Restore sensor data and register callback."""
if restored_data := await self.async_get_last_sensor_data():
self._attr_native_value = restored_data.native_value
await super().async_added_to_hass()
self._wd.register_attr_callback(self.update_from_latest_data)
"""Unregister callback."""
self._wd.unregister_attr_callback(self.update_from_latest_data)
@property
async def async_update(self) -> None:
"""Fetch updated data from the appliance."""
await self._wd.fetch_data()
@callback
def update_from_latest_data(self) -> None:
"""Calculate the time stamp for completion."""
machine_state = self._wd.get_machine_state()
now = utcnow()
if (
machine_state.value in {MachineState.Complete.value, MachineState.Standby.value}
and self._running
# Just finished a cycle, store now as end time
self._running = False
self._attr_native_value = now
self._async_write_ha_state()
if machine_state is MachineState.RunningMainCycle:
self._running = True
remaining_seconds = int(self._wd.get_attribute("Cavity_TimeStatusEstTimeRemaining"))
new_timestamp = now + timedelta(seconds=remaining_seconds)
# Only update if the new timestamp differs by more than 1 minute
if self._attr_native_value is None or (
isinstance(self._attr_native_value, datetime)
and abs(new_timestamp - self._attr_native_value) > timedelta(seconds=60)
self._attr_native_value = new_timestamp
NEW: AirCon Sensors for Current Temperature & Current Humidity
@dataclass
class WhirlpoolAirconSensorEntityDescription(SensorEntityDescription):
“”“Describes Whirlpool Aircon sensor entity (temp/humidity).”“”
AIRCON_SENSORS: tuple[WhirlpoolAirconSensorEntityDescription, …] = (
key=“current_temperature”,
name=“Current Temperature”,
device_class=SensorDeviceClass.TEMPERATURE,
state_class=SensorStateClass.MEASUREMENT,
native_unit_of_measurement=UnitOfTemperature.CELSIUS,
key=“current_humidity”,
name=“Current Humidity”,
device_class=SensorDeviceClass.HUMIDITY,
native_unit_of_measurement=PERCENTAGE,
class AirConSensor(SensorEntity):
“”“Sensor entity for Whirlpool AirCon attributes (temp/humidity).”“”
def __init__(self, aircon: Aircon, description: WhirlpoolAirconSensorEntityDescription) -> None:
"""Initialize the sensor."""
self._aircon = aircon
self._attr_unique_id = f"{aircon.said}-{description.key}"
identifiers={(DOMAIN, aircon.said)},
name=aircon.name if aircon.name else aircon.said,
model="Sixth Sense",
"""Register callback for aircon updates."""
self._aircon.register_attr_callback(self.async_write_ha_state)
self._aircon.unregister_attr_callback(self.async_write_ha_state)
@property
"""Return True if aircon is online."""
return self._aircon.get_online()
@property
def native_value(self) -> float | int | None:
"""Return the sensor value (temp or humidity)."""
if self.entity_description.key == "current_temperature":
return self._aircon.get_current_temp()
if self.entity_description.key == "current_humidity":
return self._aircon.get_current_humidity()
return None
The platform setup, registering both washer/dryer and aircon sensors
async def async_setup_entry(
hass: HomeAssistant,
config_entry: WhirlpoolConfigEntry,
async_add_entities: AddConfigEntryEntitiesCallback,
) → None:
“”“Config flow entry for Whirlpool sensors.”“”
entities: list[SensorEntity] =
appliances_manager = config_entry.runtime_data
# Washer/Dryer sensors
for washer_dryer in appliances_manager.washer_dryers:
for description in SENSORS:
entities.append(WasherDryerClass(washer_dryer, description))
for description in SENSOR_TIMER:
entities.append(WasherDryerTimeClass(washer_dryer, description))
# AirCon sensors (new)
for aircon in appliances_manager.aircons:
for desc in AIRCON_SENSORS:
entities.append(AirConSensor(aircon, desc))
async_add_entities(entities)
