Is it possible to create a white list for specific ip addresses and/or subnets when using the automatic ip banning function?
I don’t know why but my own WAN ip gets blocked about every other day. I know it is triggered by my own phone because the ban is sometimes created when I try to access the HA page.
So a white list configuration would help a lot.
Check out trusted networks.
Thanks, that would be a helpful configuration item to overcome the main issue.
beware to keep the homeassistant
provider while you add the trusted_networks
configuration
homeassistant:
auth_providers:
- type: trusted_networks
trusted_networks:
- 192.168.0.0/24
- 127.0.0.1
allow_bypass_login: true
- type: homeassistant
Hey, this has started to happen for me as well. Usually when I’m using HA I get blocked at the same time. Did you find the root cause of it? Or a good solution (I don’t want to use trusted networks because I want password to be used everywhere).
