Why can input_booleans cannot be combined to a binary group?
There a sensor groups to combine sensors.
But why cannot I add binary entities like an input_boolean to an binary group?
That doesn’t make sense…
Only binary sensors can be added to an binary group, but input_booleans (and e.g. switches) are binary, too…
I would like to combine different kind of binary entites to a group…
You can do it in yaml (so-called “old-style” groups):
In the UI sensors in a group all have to be of the same entity type - I agree, it’s quite annoying. I believe the idea is that we use the labelling system instead for mixed groups.
Hi @jackjourneyman, I know that I can do it in yaml. But in the group documentation it says you should not use the “old” groups anymore (and they don’t have any translation…). I don’t beleave that the idea is to use the labelling system, because you have to use another workflow for your automations than with the other groups…
WTH = annoying stuff. That’s one, at least in my opinion. But Thx anyway for the hint doing it with yaml :slight_smile:
My understanding of the new groups is that they are designed not to cross types. Even though things like switches are binary in nature, it cannot always safely be assumed that “On” == “True”.
You can, however, make template binary sensors from the switches and then group those.
