i spent the last two hours trying to delete, disable then delete, enable then delete, and between every attempt do a full reboot of the system. tuya is still there. what the hell man…
okay. i rebooted it and restarted my whole network and well see what happens because idk what else i can do from here…
Hi have you searched Search results for 'delete tuya' - Home Assistant Community
Nothing I found was of any help. I don’t have the custom integration I have the core one.
I tried deleting it, disabling it then deleting it. Starting it and hitting reload then deleting it. I restarted the core, the system, I added another instance after disabling the original one and all the devices said disabled because they have the same name and everything as the original devices and renaming them doesn’t help. It does not allow deletion. What steps should I take to remove it?
i updated the system and then tried again. it worked to delete it. then i installed it again and it worked.
oh it failed again. what the hell.
