Why did my scene not transition?
I just set up a couple of scenes and the only difference between them is the state of a GE direct connect smart bulb.
I thought I had it set up so that the light would dim over 5 minutes at 10pm, but I watched it this evening and it just turned off instead of dimming.
What do I need to do to make the transition gradual rather than instant?
Here’s my relevant yaml:
automation:
  - action: scene.turn_on
    metadata: {}
      transition: 300
      entity_id: scene.birdssleep
new scene
entities:
  light.cynclamp_01:
    state: "off"
previous scene:
entities:
  light.cynclamp_01:
    state: "on"
Does the light support transitions? If it does not, it will not work. You may also try rather than transitioning to state off instead going to brightness 0.
I have a similar issue with scenes.
I have HUE lights and HUE scenes trough the HUE integration.
If I use HUE app then the transitions work, if I call the same scenes with an home assistant automation the transition dosn´t work and the switch is instant.
