And this one does not:
esphome:
friendly_name: Kitchen Display
on_boot:
then:
- delay: 200s
- component.update: epaperDisplay
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "redacted"
ota:
- platform: esphome
password: "redacted"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Kitchen Display Fallback"
captive_portal:
time:
- platform: homeassistant
text_sensor:
entity_id: sensor.weather
internal: true
attribute: icon
internal: true
entity_id: input_text.motd
internal: true
entity_id: sensor.temperature
entity_id: sensor.uv_index
entity_id: sensor.hall_sensor_temperature
#- platform: homeassistant
# id: solar_excess
# entity_id: sensor.smart_meter_electricity_power
# filters:
# - lambda: !lambda |-
# if (x < 0) { return 0.0-x; } else { return 0; } ;
entity_id: sensor.esphome_web_ccba78_bat_soc
- platform: wifi_signal
update_interval: 60s
graph:
# Show bare-minimum auto-ranged graph
- id: single_power_graph
sensor: solar_excess
duration: 1h
width: 250
height: 101
font:
- file: "fonts/DejaVuSans.ttf"
- file: "fonts/MaterialDesignIconsDesktop.ttf"
glyphs: [
"\U000F05D6", # alert-circle-outline - exeptionnal
"\U000F002A", # alert-outline
"\U000F058E", # water-percent
"\U000F0D43", # air-filter
"\U000F0F2F", # weather-cloudy-alert
"\U000F0590", # weather-cloudy
"\U000F0594", # weather-night - clear-night
"\U000F0F31", # weather-night-partly-cloudy
"\U000F0591", # weather-fog
"\U000F0592", # weather-hail
"\U000F0593", # weather-lightning
"\U000F067E", # weather-lightning-rainy
"\U000F0595", # weather-partly-cloudy
"\U000F0F32", # weather-partly-lightning
"\U000F0F33", # weather-partly-rainy
"\U000F0F34", # weather-partly-snowy
"\U000F0F35", # weather-partly-snowy-rainy
"\U000F0596", # weather-pouring
"\U000F0597", # weather-rainy
"\U000F0598", # weather-snowy
"\U000F0F36", # weather-snowy-heavy
"\U000F067F", # weather-snowy-rainy
"\U000F0599", # weather-sunny
"\U000F059D", # weather-windy
"\U000F059E", # weather-windy-variant
"\U000F050F" # thermometer
glyphs: [
"\U000F050F", # thermometer
"\U000F0079", # mdi:battery #full
"\U000F007A", # mdi:battery-10
"\U000F007B", # mdi:battery-20
"\U000F007C", # mdi:battery-30
"\U000F007D", # mdi:battery-40
"\U000F007E", # mdi:battery-50
"\U000F007F", # mdi:battery-60
"\U000F0080", # mdi:battery-70
"\U000F0081", # mdi:battery-80
"\U000F0082", # mdi:battery-90
"\U000F1902", # mdi:home-battery-outline
"\U000F1A74", # mdi:solar-power-variant-outline
"\U000F17FF" # mdi:sun-wireless-outline
glyphs: [
glyphs: [
"\U000F092B", # wifi-strength-alert-outline
"\U000F092F", # wifi-strength-outline not in below range
"\U000F091F", # wifi-strength-1 >= -100
"\U000F0922", # wifi-strength-2 >= -75
"\U000F0925", # wifi-strength-3 >= -60
"\U000F0928" # wifi-strength-4 >= -50
spi:
clk_pin: 13
mosi_pin: 14
display:
- platform: waveshare_epaper
cs_pin: 15
dc_pin: 27
busy_pin: 25
# number: 25
# inverted: true
reset_pin: 26
reset_duration: 2ms
update_interval: 600s #update every 10 minutes
rotation: 0
model: 7.50in-bV3
lambda: |-
// screen section coordinates
int width = it.get_width();
int height = it.get_height();
int centre = width /2;
int tTop = 10;
int tBottom = tTop + (height - 10) / 2;
//int mTop = tBottom + 1;
//int mBottom = mTop + (height - 10) / 2;
int BTop = tBottom + 1;
int BBottom = BTop + (height - 10) / 2;
// Header 0 to 9
std::string iconstr("\U000F092B"); //it is off to start so set that and change if we have anything better
if(id(wifisignal).has_state()) {
if (id(wifisignal).state >= -50) {
//Excellent
iconstr = "\U000F0928";
} else if (id(wifisignal).state >= -60) {
//Good
iconstr = "\U000F0925";
} else if (id(wifisignal).state >= -75) {
//Fair
iconstr = "\U000F0922";
} else if (id(wifisignal).state >= -100) {
//Weak
iconstr = "\U000F091F";
} else {
//Unlikely working signal
iconstr = "\U000F092B";
it.printf(width - 1, 0, id(mdi14), TextAlign::TOP_RIGHT, iconstr.c_str());
// centre divider
it.line(centre , tTop + (tBottom - tTop)/2, centre, BTop + (BBottom - BTop)/2 );
//Date Time
it.strftime((width - centre) /2, tTop, id(djsans60), TextAlign::TOP_CENTER, "%A", id(homeassistant_time).now());
it.strftime((width - centre) /2, tTop + 70, id(djsans40), TextAlign::TOP_CENTER, "%d %B %Y", id(homeassistant_time).now());
// removing the time feature as screen does not do quick partial updates
// it.strftime(width /2, 120, id(djsans40), TextAlign::TOP_CENTER, "%H:%M", id(homeassistant_time).now());
// Top Right
//it.line(centre + centre/2 , tTop, centre + centre/2, tTop + 100);
std::string thermometer("\U000F050F");
it.printf(centre + centre/2, tTop + 4, id(mdi60), TextAlign::TOP_CENTER, thermometer.c_str());
//temp in
it.printf(centre + centre/4, tTop + 2, id(djsans30), TextAlign::TOP_CENTER, "Inside");
it.printf(centre + centre/4, tTop + 42, id(djsans40), TextAlign::TOP_CENTER, "%.1f°c", id(internal_temperature).state);
//temp out
it.printf(width - centre/4, tTop + 2, id(djsans30), TextAlign::TOP_CENTER, "Outside");
it.printf(width - centre/4, tTop + 44, id(djsans40), TextAlign::TOP_CENTER, "%.0f°c", id(external_temperature_3h).state);
std::string sunWifi("\U000F17FF");
it.printf(centre + centre/2, tTop + (tBottom - tTop)/2, id(mdi30), TextAlign::TOP_RIGHT, sunWifi.c_str());
it.printf(centre + centre/2, tTop + (tBottom - tTop)/2, id(djsans30), TextAlign::TOP_LEFT, "%.0f", id(UVIndex_3h).state);
if (id(weather_3hr).has_state()) {
std::map<std::string, std::string> weather_state {
{ "sunny", "\U000F0599" }, // mdi:weather-sunny
{ "clear-night", "\U000F0594" }, // mdi:weather-night
{ "cloudy", "\U000F0590" }, // mdi:weather-cloudy
{ "rainy", "\U000F0597" }, // mdi:weather-rainy
{ "pouring", "\U000F0596" }, // mdi:weather-pouring
{ "sleet", "\U000F067F" }, // mdi:weather-snowy-rainy
{ "lightning-rainy","\U000F067E"}, // mdi:weather-lightning-rainy
{ "lightning","\U000F0593"}, // mdi:weather-lightning
{ "snowy", "\U000F0598" }, // mdi:weather-snowy-heavy
{ "wind", "\U000F059E" }, // mdi:weather-windy-variant
{ "fog", "\U000F0591" }, // mdi:weather-fog
{ "partlycloudy", "\U000F0595" }, // mdi:weather-partly-cloudy
{ "partly-cloudy-night", "\U000F0F31" } // mdi:weather-night-partly-cloudy
std::map<std::string, std::string> weather_state_mdi {
{ "mdi:weather-cloudy-alert", "\U000F0F2F" }, //# weather-cloudy-alert
{ "mdi:weather-cloudy", "\U000F0590" }, //# weather-cloudy
{ "mdi:weather-clear-night", "\U000F0594" }, //# weather-night
{ "mdi:weather-night-partly-cloudy", "\U000F0F31" }, //# weather-night-partly-cloudy
{ "mdi:weather-fog", "\U000F0591" }, //# weather-fog
{ "mdi:weather-hail", "\U000F0592" }, //# weather-hail
{ "mdi:weather-lightning", "\U000F0593" }, //# weather-lightning
{ "mdi:weather-lightning-rainy", "\U000F067E" }, //# weather-lightning-rainy
{ "mdi:weather-partly-cloudy", "\U000F0595" }, //# weather-partly-cloudy
{ "mdi:weather-partly-lightning", "\U000F0F32" }, //# weather-partly-lightning
{ "mdi:weather-partly-rainy", "\U000F0F33" }, //# weather-partly-rainy
{ "mdi:weather-partly-snowy", "\U000F0F34" }, //# weather-partly-snowy
{ "mdi:weather-partly-snowy-rainy", "\U000F0F35" }, //# weather-partly-snowy-rainy
{ "mdi:weather-pouring", "\U000F0596" }, //# weather-pouring
{ "mdi:weather-rainy", "\U000F0597" }, //# weather-rainy
{ "mdi:weather-snowy", "\U000F0598" }, //# weather-snowy
{ "mdi:weather-snowy-heavy", "\U000F0F36" }, //# weather-snowy-heavy
{ "mdi:weather-snowy-rainy", "\U000F067F" }, //# weather-snowy-rainy
{ "mdi:weather-sunny", "\U000F0599" }, //# weather-sunny
{ "mdi:weather-windy", "\U000F059D" }, //# weather-windy
{ "mdi:weather-windy-variant", "\U000F059E" } //# weather-windy-variant
//if(weather_state.count(id(weather_3hr).state.c_str()) > 0 ) {
// it.printf(centre + centre/2, tTop + (tBottom - tTop)/2 + 50, id(mdi100), TextAlign::TOP_CENTER, weather_state[id(weather_3hr).state.c_str()].c_str());
if(weather_state_mdi.count(id(weather_icon).state.c_str()) > 0 ) {
it.printf(centre + centre/2, tTop + (tBottom - tTop)/2 + 50, id(mdi100), TextAlign::TOP_CENTER, weather_state_mdi[id(weather_icon).state.c_str()].c_str());
else {
it.printf(centre + centre/2, tTop + (tBottom - tTop)/2 + 50, id(djsans30), TextAlign::TOP_CENTER, id(weather_3hr).state.c_str());
it.printf(centre + centre/2, tTop + (tBottom - tTop)/2 + 100, id(djsans30), TextAlign::TOP_CENTER, id(weather_icon).state.c_str());
// Bottom Right
std::string houseBat("\U000F1902");
it.printf(centre + centre/4, BTop + 50, id(mdi30), TextAlign::TOP_CENTER, houseBat.c_str());
std::string sunsol("\U000F1A74");
it.printf(centre + centre/2, BTop + 50, id(mdi30), TextAlign::TOP_CENTER, sunsol.c_str());
it.printf(centre + centre/4, BTop + 80, id(djsans30), TextAlign::TOP_CENTER, "%2.0f%%", (id(battery_soc).state -20)*100/80 );
it.printf(centre + centre/2, BTop + 80, id(djsans30), TextAlign::TOP_CENTER, "%.1fkw", - id(solar_excess).state );
// BOTTOM
it.printf(width/2, BBottom - (BBottom - BTop)/4, id(djsans30), TextAlign::TOP_CENTER, id(MOTD).state.c_str());
// Footer last 10
