I don’t know whether something has changed in HA but an automation I have had working for some time has stopped working.
It triggers based on temperature dropping below a certain amount (with a condition to check whether I am in a peak rate on my electricity tariff).
The automation stops being triggered anymore even when the temperature keeps dropping, as I can see there are no traces available.
Here are the traces available as an example:
As you can see the last trigger was 18:42:17, however the temperature sensor it triggers on has dropped down a few more times since then:
Why wasn’t the automation triggered at 21:28 when it changed to 4 degrees?
This is the automation:
alias: Studio heater - auto on, low temperature
description: Turn on heater if low temperature and it's not Octopus Flux peak time
- platform: numeric_state
entity_id: sensor.studio_motion_sensor_air_temperature_2
below: "6"
condition:
- condition: not
conditions:
- condition: state
entity_id: select.octopus_electricity
state: Peak
- service: switch.turn_on
data: {}
entity_id: switch.studio_heater_switch
data: {}
entity_id: input_boolean.studio_heater_low_temperature_triggered
- service: notify.mypushover
message: Studio heater turned on as it's very low temperature
mode: single
I can’t see anything in the logs explaining this?
Thanks for any help you can offer
