Why does my routine not run after wakeup?
I migrated a device to a Lolin D32. Before, it ran on a different ESP32 board. It worked really well except that it used too much power.
Now, on my LolinD32, the code does what it should (activatings externals, measuring, using those measurements to run a motor, going to sleep) when it is turned on. If it wakes up from deep sleep, it does nothing of that. It doesn’t matter if I use the wakeup pin I have set up, or if it wakes up from sleep after a fixed time.
All it does is printing this to the log, and after that it stays awake:
[15:33:13][I][ota:113]: Boot seems successful, resetting boot loop counter.
[15:33:13][D][esp32.preferences:114]: Saving 1 preferences to flash…
[15:33:13][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
…after that nothing happens…
Why does the rutine I set up in my YAML only run on a hard boot and not on a wakeup from deep sleep?
Impossible to say without seeing your device’s yaml configuration.
Here you go:
# GPIO	Connected to
# 33	Moisture Meter
# 23	Pump (thru Mosfet)
# 0	Action Button
# 13 water level power
# 35,25,26, 27,14,	Water level sensors
# 32	Battery level
substitutions:
  esp_name: flaura9
  esp_id: flaura9
  soil_moisture_threshold: "85" # %
  watering_time: 5s
  long_sleep: 24 h
  short_sleep: 2 min
  sleep_prevention_duration: 0 min
  waterLevelSensorThreshold: "0.1" # V
# Enable Home Assistant API
api:
  encryption:
    key: "NoBeITWzY5mJNUVnVor/fNlI1PieOyE6YujHhtA/1jk="
ota:
  password: "fe66a5de37b1805a89749336c83a77c9"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Flaura9 Fallback Hotspot"
    password: "bA75C1T6cB49"
<<: !include flaura_main.yaml
and then, in flaura_main:
esphome:
  on_boot:
    priority: 900.0
    then:
      - delay: 1s
      - switch.turn_off: ${esp_id}_power_moisture_sensor
      - switch.turn_off: ${esp_id}_power_pump
      - script.execute: run
time:
  - platform: homeassistant
esp32:
  board: esp32dev
  framework:
    type: arduino
deep_sleep:
  run_duration: 10h
  wakeup_pin:
    number: GPIO00
    inverted: true
        # Enable logging
logger:
captive_portal:
switch:
  - platform: gpio
    pin: 19
    name: ${esp_id} power moisture sensor #green wire
  - platform: gpio
    pin: 23
    name: ${esp_id} power pump
  - platform: gpio
    pin: 13
    name: ${esp_id} power water level
binary_sensor:
    entity_id: input_boolean.allow_flaura_deep_sleep
  - platform: gpio
    pin: 27
    id: "${esp_id}_water_level_sensor_10" #yellow wire
    name: ${esp_id} water level sensor 10
    filters:
      - delayed_on: 400ms
  - platform: gpio
    pin: 26
    id: "${esp_id}_water_level_sensor_30" #white wire
    name: ${esp_id} water level sensor 30
    filters:
      - delayed_on: 400ms
  - platform: gpio
    pin: 25
    id: "${esp_id}_water_level_sensor_50" #red wire
    name: ${esp_id} water level sensor 50
    filters:
      - delayed_on: 400ms
    name: ${esp_id} water present
  - platform: adc
    pin: 33
    name: "${esp_name} soil moisture"
    unit_of_measurement: "%"
    attenuation: 11dB
    filters:
      - median:
          window_size: 11
          send_every: 11
          send_first_at: 11
      - calibrate_linear:
        - 0.84 -> 100.00
        - 2.40 -> 0.00
      - lambda: |
          if (x < 0) return 0;
          else if (x > 100) return 100;
          else return (x);
    accuracy_decimals: 0
    update_interval: never
  - platform: adc
    pin: GPIO35
    name: "${esp_name} battery raw"
    accuracy_decimals: 2
    attenuation: 11dB
    filters:
      - median:
          window_size: 11
          send_every: 11
          send_first_at: 11
      - multiply: 2.0
    unit_of_measurement: '%'
    lambda: |-
      return (id(${esp_id}_battery_raw).state - 3.5) / 0.6; // Current change minus minimum Devided by max minus min  (4.1 - 3.5)
script:
  - id: run
    mode: queued
    then:
      - script.execute: measure_battery_level
      - script.execute: measure_soil_moisture
      - script.execute: water_plant
      - script.wait: water_plant
      - delay: 1s
  - id: measure_soil_moisture
    then:
      - switch.turn_on: ${esp_id}_power_moisture_sensor
      - lambda: |-
          for (int i = 0; i < 11; i++) {
            delay(100);
            id(${esp_id}_soil_moisture).update();
  - id: water_plant
    then:
      - switch.turn_on: ${esp_id}_power_water_level
      - delay: 2s
      - if:
          condition:
             binary_sensor.is_on: ${esp_id}_water_level_sensor_10
          then:
            - binary_sensor.template.publish:
                state: ON
          else:
                state: OFF
      - if:
          condition:
            lambda: |-
              return ((id(${esp_id}_soil_moisture).state < ${soil_moisture_threshold}) && (id(${esp_id}_water_level_sensor_10).state));
          then:
            - switch.turn_on: ${esp_id}_power_pump
            - delay: ${watering_time}
            - script.execute: enter_short_sleep
          else:
            - script.execute: enter_long_sleep
  - id: measure_battery_level
    then:
      - component.update: ${esp_id}_battery_raw
      - lambda: |-
            id(${esp_id}_battery_raw).update();
            delay(200);
  - id: enter_long_sleep
    then:
    - switch.turn_off: ${esp_id}_power_water_level
    - delay: 2 s
    - if:
        condition:
          binary_sensor.is_on: allow_flaura_deep_sleep
        then:
#          - delay: ${sleep_prevention_duration}
          - logger.log: "enter sleep"
          - deep_sleep.enter:
              sleep_duration: ${long_sleep}
        else:
          - logger.log: "long sleep prevented from HA"
  - id: enter_short_sleep
    then:
    - delay: 5s
    - if:
        condition:
          and:
            - binary_sensor.is_on: allow_flaura_deep_sleep
            - wifi.connected:
        then:
          - logger.log: "enter long sleep"
          - deep_sleep.enter:
              sleep_duration: ${short_sleep}
        else:
That’s a pretty high boot priority. That’s before the switches have even been initialised.
Try it after wifi is set up at about 200.
Have you tried adding things that help with faster connection? Like static ip.
I’ve found sometimes you can miss early boot logs which could help troubleshoot.
I think logger is maybe set up a bit later. Like around where Tom is suggesting.
I also add in custom logger messages around the place when I’m trying to debug.
Have you thought about making these
restore_mode: ALWAYS_OFF
(if it’s available and it works? I know sometimes people report unexpected behaviour with that feature)
That would then possibly let ESPHome manage it at the right time.
I’m taking a bit of interest in your code as I’m comparing our irrigation projects to see if there’s things you are doing that I like better than mine.
Here’s an excerpt of my boot. Shout out if this is off topic and you want to stay on topic.
On Boot and shutdown snippets
  on_boot:
    # #Try this if sensors don't boot. https://community.home-assistant.io/t/add-sensor-delay-upon-power-on/158567/6?u=mahko_mahko
    # https://community.home-assistant.io/t/i2c-bus-scan-after-deep-sleep-recovery/524925/7?u=mahko_mahko
    - priority: 900
      then:
      - lambda: |-
          Wire.begin();
          delay(500);
    - priority: -100
      then:
        #Reset sensor update counters. These are for debugging.
        - lambda: id(count_irrigation_lux).publish_state(0);
        - lambda: id(count_batt_voltage).publish_state(0);
        - lambda: id(count_irrigation_tof).publish_state(0);
        - delay: 1s
        #Auto sensor updates are turned off and manually requested on boot. These are multi-sampled and then aggregated.
        #The ESP then goes back to sleep when they're done (unless told to stay awake).
          #Request sensor updates
        - logger.log: "....Starting sensor updates"
        - repeat:
            count: 5 #Update cycles
            then:
              - component.update: batt_voltage #Battery level
              - delay: 100ms
              - component.update: soil_moisture_voltage #Moisture level
              - delay: 100ms
              - component.update: tof #Water tank level
              - delay: 100ms
              - component.update: irrigation_lux #Light level
              - delay: 100ms
            #second pass for ADC based sensors which benefit from more samples.
              - delay: 250ms
              - delay: 250ms
  on_shutdown:
    priority: -100
    then:
      - if:
          condition:
            - binary_sensor.is_on: all_updates_recieved
          then:
            - logger.log: "Data updates ok..."
          else:
            - logger.log: "A sensor might be down...missing updates"
                state: ON
            - delay: 1s
      - switch.turn_off: pump #Probably not required....
    #Turn off 5v peripheral power. It will retore as on when it wakes.
      - logger.log: "Turning off peripheral power..."
      - switch.turn_off: power_peripherals
    #Turn off the "Fresh data recieved sensors"
          state: OFF
          state: OFF
          state: OFF
          state: OFF
          state: OFF
I tried and tested this, and it works. Thanks, @tom_l , I could have spend weeks figuring out it was this line that was causing issues.
Thank you for your fine suggestions.
Yes, I have tried faster connections with static IP and fast-connect. It was mostly to save battery, though. It was giving me all sorts of trouble connecting. Maybe it was due to the onboot-issue that tom_l fixed. I should probably give it a try again.
As for restore_mode: ALWAYS_OFF… What I have today is working. I think I’ll stick with that.
