I develop eedc (Energy Efficiency Data Center), an open-source Home Assistant add-on for PV system analysis. One question I get regularly: “Why do you keep adding support for inverters and devices you don’t even have?”
The answer is the anonymous Community Benchmark at https://energy.raunet.eu.
The idea
PV system owners can anonymously compare their key metrics — self-consumption ratio, autarky, specific yield, ROI, heat pump COP — against similar installations. No registration, no tracking, fully anonymous.
Why device diversity matters
A benchmark is only as good as its data. If only one brand of inverter is represented, the comparison is meaningless. Every new integration lowers the barrier for another participant — and another data point that makes the benchmark more useful for everyone.
Currently supported data sources:
- Cloud import: SolarEdge, Fronius, Huawei, Growatt, Deye/Solarman
- Local connectors: SMA, Fronius, Kostal, Shelly, OpenDTU, sonnenBatterie, Tasmota, go-eCharger
- HA sensors and MQTT inbound as universal bridges (works with any setup)
- Portal import: SMA Sunny Portal, Fronius Solar.web, EVCC
The HA sensor mapping and MQTT path mean that technically any device already in your Home Assistant can feed data into eedc — the dedicated connectors and cloud imports just make it more convenient.
How you can help
- Try the benchmark and see how your system compares: https://energy.raunet.eu
- Share API documentation for your inverter/battery if it’s not yet supported
- Report issues or contribute on GitHub: 4. Reddit r/homeassistant (English, casual, concise)
Title: Why I keep adding inverter support for devices I don’t own
I maintain eedc, an open-source HA add-on for PV analysis. People sometimes ask why I build integrations for Fronius, Huawei, Growatt, etc. when I only have SMA myself.
