Why I can't add Lilygo T18 to HA, even though ESP32-S2 works fine
Hi! I am trying to connect Lilygo T18 (GitHub - LilyGO/LILYGO-T-Energy), which is ESP32-wroover with integrated 18650 battery cradle to HomeAssistant.
My problem is that every time I flash a device, HA finds it again, offers to add it, but there are no devices or objects in the list. I have tried several times to connect different sensors to the board and configure them via YAML, but this does not change the situation: I can read logs from the device via Wi-Fi, but entities do not appear.
At the same time, everything works fine with the usual ESP32-S2, and apparently it’s because of some features of the board itself.
Here is my YAML:
esphome:
  friendly_name: liligo-t18
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXX"
ota:
  - platform: esphome
    password: "XXX"
wifi:
  ssid: !secret wifi_ssid
deep_sleep:
  run_duration: 5min
  sleep_duration: 5min
# BATTERY VOLTAGE
  - platform: adc
    pin: GPIO35
    update_interval: 30s
    accuracy_decimals: 3
    unit_of_measurement: "V"
    filters:
      - multiply: 3.6590
How to start trouble shooting?
Until you have it perfectly working, at least remove the deep sleep.
After many attemps of renaming and reflashing device, I suddenly found that device changes it’s IP address after reboot.
How to solve it?
Try static IP.
The log says the MAC address changed. That is not the IP address.
It also looks like you have two devices with the same name, which seems like a not so good idea.
also, the names in the log don’t match the name in the picture nor the name in the YAML.
Solution was that way:
esp32:
  board: esp32dev
  framework:
    type: arduino
    advanced:
      ignore_efuse_custom_mac: true
It was something ugly with MAC address of board, and that solved problem
