Hi there! I’m trying to modularize my configuration for a shelly 1 to be able to make it work in detached mode, add multi click capabilities and send mqtt messages (with fallback to simple toggle when connection is down) based on the type of click.
The main config file has these lines:
substitutions:
device_name: interruttore-camera
friendly_name: Interruttore camera
relay_id: shelly_relay
button_id: button1
binary_sensor:
- platform: gpio
pin: GPIO5
internal: true
filters:
delayed_on_off: 50ms
on_multi_click: !include on-multi-click.yaml
on-multi-click.yaml
contains the following
- timing:
- ON for at most 0.5s
- OFF for at most 0.5s
- OFF for at least 0.2s
then: !include
file: publish-mqtt-or-toggle.yaml
vars:
payload: double
- timing:
- ON for at least 0.2s
then: !include
vars:
payload: double
- timing:
- OFF for at least 0.5s
then: !include
vars:
payload: single
- timing:
- ON for at least 0.5s
then: !include
vars:
payload: single
- timing:
- ON for at least 1.5s
then: !include
vars:
payload: long
- timing:
- OFF for at least 1.5s
then: !include
vars:
payload: long
And then the publish-to-mqtt-or-toggle.yaml
looks like this:
- if:
condition:
and:
- wifi.connected:
- mqtt.connected:
- switch.is_on: ${relay_id}
then:
- mqtt.publish_json:
topic: homie/${device_name}/${button_id}/status
payload: ${payload}
else:
- switch.toggle: ${relay_id}
If I try to compile the configuration I got weird messages such as
publish-mqtt-or-toggle.yaml: In lambda function:
publish-mqtt-or-toggle.yaml:13:3: error: expected unqualified-id before '}' token
publish-mqtt-or-toggle.yaml:12:7: error: 'single' was not declared in this scope; did you mean 'sinl'?
using esphome config
I realized that the payload variable is turned into a lambda, and the “long”, “double” and “single” values are taken as C types instead of actual values.
substitutions:
button_id: button1
binary_sensor:
- platform: gpio
name: Interruttore camera Input
pin:
number: 5
mode:
input: true
output: false
open_drain: false
pullup: false
pulldown: false
analog: false
inverted: false
internal: true
filters:
- delayed_on_off: 50ms
on_multi_click:
- timing:
- state: true
min_length: 0ms
max_length: 500ms
- state: false
min_length: 0ms
max_length: 500ms
- state: true
min_length: 0ms
max_length: 500ms
- state: false
min_length: 200ms
then:
- if:
condition:
and:
- wifi.connected: {}
- mqtt.connected: {}
- switch.is_on:
then:
topic: homie/interruttore-camera/button1/status
payload: !lambda |-
double
qos: 0
retain: false
else:
- switch.toggle:
invalid_cooldown: 1s
- timing:
- state: false
min_length: 0ms
max_length: 500ms
- state: true
min_length: 0ms
max_length: 500ms
- state: false
min_length: 0ms
max_length: 500ms
- state: true
min_length: 200ms
then:
- if:
condition:
and:
- switch.is_on:
then:
payload: !lambda |-
double
qos: 0
retain: false
else:
- switch.toggle:
- timing:
- state: true
min_length: 0ms
max_length: 500ms
- state: false
min_length: 500ms
then:
- if:
condition:
and:
- switch.is_on:
then:
payload: !lambda |-
single
qos: 0
retain: false
else:
- switch.toggle:
- timing:
- state: false
min_length: 0ms
max_length: 500ms
- state: true
min_length: 500ms
then:
- if:
condition:
and:
- switch.is_on:
then:
payload: !lambda |-
single
qos: 0
retain: false
else:
- switch.toggle:
- timing:
- state: true
min_length: 1500ms
then:
- if:
condition:
and:
- switch.is_on:
then:
payload: !lambda |-
long
qos: 0
retain: false
else:
- switch.toggle:
- timing:
- state: false
min_length: 1500ms
then:
- if:
condition:
and:
- switch.is_on:
then:
payload: !lambda |-
long
qos: 0
retain: false
else:
- switch.toggle:
disabled_by_default: false
Am I doing something wrong or hitting an unkown issue? I’ve searched through esphome issues and this forum, but I cannot find anything like this…
