My TRVZBs have been turned off for the summer and now when I wanted to start them on a schedule I can’t boot them up.
They are only showing iN on the display and nothing seems to start. 1 started once with F5 error ( no valve detected ) but when I turned it off and started it back up it got back to iN.
You do have it mounted on your valve? Because F5 error shows if the head is not mounted on valve and it can’t detect valve’s pin moving (it seems that it detects pin resistance when closing). If you’re holding it in your hands it won’t work.
