Why is the esphome dashboard showing only some yaml names
Hello, i have a coue esphome configs/devices and i unified there coding.
But for some reason, the dashboard is showing them differently.
Some show only the lower case and upper case name, some show the file name.yaml as well.
Is there a logic to this?
They all work and its most likely just cosmetics but i would like to understand why.
Thx in advanxe
What are the yaml files named?
Pretty much striaght forward what they are emant to be i hope
The first title is the device name you set inside the yaml file. The one below it is the file name but it is only shown if different from the device name.
There’s also an option to refresh the device name if you change it. In the three dots menu for each device
Oh wow thx, didnt see that pattern myself.
Now that u pointed it out it makes clear sense.
Thx alot
Personally I think it is confusing and the file-name should always be shown under the device name.
