zBernie
(Bernie)
March 6, 2026, 4:04am
1
The automation below is for a Sonoff smart button which controls lights in my kitchen. There is a “Button pressed” trigger, and also a “Button double clicked” trigger. I don’t understand why if I press the button once, the “got here” message is displayed in the “Button double clicked” if block. Since I’m only pressing the button once, how is it executing anything in the second if statement when the condition is “if triggered by double click”. I don’t see how “got here” is being displayed when I single click.
Note: For some reason when I click the “Copy to clipboard” button it is only copying the first line. I had to select all the text then copy the YAML. Not sure why.
-Thanks
alias: Kitchen Lights Button
description: ""
triggers:
- device_id: c4dd32bbddf508fd858abb8232285174
domain: zha
type: remote_button_short_press
subtype: button
trigger: device
domain: zha
type: remote_button_double_press
subtype: button
trigger: device
conditions: []
actions:
- if:
- condition: trigger
id:
- button pressed
- condition: state
entity_id: light.cync_full_color_undercabinet_18_2
state:
- "off"
then:
- action: light.turn_on
metadata: {}
data: {}
entity_id:
- light.cync_full_color_undercabinet_18_2
else:
- action: light.turn_off
metadata: {}
entity_id:
data: {}
- if:
id:
- double clicked
- condition: state
entity_id: switch.ceiling_lights
state:
- "off"
then:
metadata: {}
entity_id:
data: {}
- action: switch.turn_on
metadata: {}
data: {}
else:
- action: persistent_notification.create
metadata: {}
message: got here
metadata: {}
data: {}
entity_id:
- action: switch.turn_off
metadata: {}
data: {}
enabled: true
mode: single
It’s doing the actions in the else block, just like it should.
zBernie
(Bernie)
March 6, 2026, 4:19am
3
I was thinking that this if block including the “else” would only be executed if the condition of double click was satisfied. I still don’t get how it is executing the else statement in this block.
-Thanks
zBernie
(Bernie)
March 6, 2026, 4:56am
4
I added this conditional after the else to prevent the else part from being executed. I still don’t see why it executes when this if statement is executed via the double click trigger.
condition: state
state:
- "on"
You have 2 If/Then actions that are independent of one another. No matter which trigger fires, at least one of the Else clauses will be executed.
If your sets of actions are mutually exclusive, you may be better off using a Choose action, instead of (or in conjunction with) the two If/Thens.
You can do any of the following:
Option 1: Add a condition to each Else
description: ""
triggers:
domain: zha
subtype: button
trigger: device
domain: zha
subtype: button
trigger: device
conditions: []
actions:
- if:
- condition: state
state: "off"
then:
entity_id:
else:
entity_id:
- if:
- condition: state
state: "off"
then:
entity_id:
else:
message: got here
entity_id:
enabled: true
mode: single
Option 2: If/Thens in a Choose
description: ""
triggers:
domain: zha
subtype: button
trigger: device
domain: zha
subtype: button
trigger: device
conditions: []
actions:
- choose:
- conditions:
sequence:
- if:
- condition: state
state: "off"
then:
entity_id:
else:
entity_id:
- conditions:
sequence:
- if:
- condition: state
state: "off"
then:
entity_id:
else:
message: got here
entity_id:
mode: single
Option 3: A Choose and a couple templates
description: ""
triggers:
domain: zha
subtype: button
trigger: device
domain: zha
subtype: button
trigger: device
conditions: []
actions:
- choose:
- conditions:
sequence:
- action: light.turn_{{ 'on' if is_states('light.cync_full_color_undercabinet_18_2','off') else 'off' }}
metadata: {}
data: {}
entity_id:
- conditions:
sequence:
- action: homeassistant.turn_{{ 'on' if is_states('switch.ceiling_lights','off') else 'off' }}
metadata: {}
entity_id:
- switch.ceiling_lights
mode: single
zBernie
(Bernie)
March 6, 2026, 5:08am
6
Thanks, I’ll take a look at this tomorrow.
Troon
(Troon)
March 6, 2026, 7:26am
7
What do you imagine “else” means?
If I win the lottery
Then cheer and jump around
Else rip the ticket up and throw the bits in the bin
zBernie
(Bernie)
March 6, 2026, 12:19pm
8
That’s funny! But I thought the difference was that the second “else” was in a completely different “if” block triggered by a different trigger. Evidently it doesn’t work that way.
zBernie
(Bernie)
March 6, 2026, 12:51pm
9
Thanks again I really appreciate your help with this. I’ve been using the Choose option when multiple triggers were involved. I thought the If/Then was a bit cleaner. Just have to add the conditions and I should be good to go.
And after 4 months of using Home Assistant I thought I knew it all!
