Hey, I wanted to install HAOS on another instance, so I backed up my data, installed HAOS onto the new mini PC and started the backup restore. I let it go on for over 8 hours at this point and nothing has changed. What should I do?
It takes a while sometimes, but here is a search term to get you posts about how to check what it’s doing or if it’s done. Put this into a search engine.
site:community.home-assistant.io backup finish?
Update: I think the problem has to do with the backup structure or something, because my old instance was a virtual machine in proxmox and my new one was a native installation on a mini PC. I just took an older backup from before I had the virtual machine instance. If you don’t have one I think you can also just take the old YAML files out of the backup and just switch them with the new ones on your new instance after installing home Assistant OS.
