Why isn't this variable working?
I have a Sonos speaker, and the song title info in template editor is:
{{ (state_attr('media_player.kjokken', 'media_title')) }}
This works as it should. I am trying to put this into an automation to send it with a REST command to another system (which doesn’t support MQTT or anything else, so it has to be REST). This is the defined rest command:
rest_command:
  girder:
    url: http://192.168.1.100:9876/nodered.html?1={{ kommandoklasse }}&2={{ kommando }}&3={{ sone }}&4=SECRET_PASSWORD_TO_THE_SYSTEM
    method: GET
    verify_ssl: false
And this is the automation I am trying to get right:
alias: Vise hva Sonos spiller
description: ""
triggers:
  - trigger: state
    entity_id:
      - media_player.kjokken
    attribute: media_title
conditions:
  - condition: state
    entity_id: media_player.kjokken
    state: playing
actions:
  - variables:
      avspillingsinfo: |
  - alias: Sende det som spiller
    metadata: {}
      kommandoklasse: Nettradioinfo
      kommando: |
        {avspillingsinfo}
      sone: 2
    action: rest_command.girder
mode: single
But it arrives as kommandoklasse (command class ) “Nettradioinfo” with kommando (command) empty. I tried to use > instead of | but that’s changed when I close and reopen the automation. What am I doing wrong here?
I first tried a simpler version, with only one action, but that didn’t work either:
metadata: {}
  kommando: >
  sone: 2
In your first example, if you want to get the value of the variable avspillingsinfo, you need to write {{ avspillingsinfo }}. Currently you have only a single curly bracket.
You also probably don’t want to use | to define a value that you’re going to put into a URL-encoded string. > is probably a better choice.
The simpler example should work, assuming that you’ve got the entity_id and attribute name correct. What do you see when you paste
into Developer Tools → Template Editor?
Thanks for answering! Right now it shows:
Lørdagskveld i NRK P1: Try sleeping with a broken heart, Alicia Keys
As I said in the first post, that works. Weird that it doesn’t work in the test, then. :grimacing:
Oh, sorry. Adding second pair of curly braces didn’t change anything in the complicated version.
Did you say that you tried to change the | to a >, but when you reopen the automation after changing it, it’s still |? That’s somewhat troubling.
Try this:
description: ""
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
    state: playing
actions:
  - variables:
      avspillingsinfo: "{{ state_attr('media_player.kjokken', 'media_title') }}"
    metadata: {}
      kommando: "{{avspillingsinfo}}"
      sone: 2
mode: single
Hm… It still sends an empty kommando.
What do you see in the alert that happens if you try this automation (added an action at the end):
description: ""
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
    state: playing
actions:
  - variables:
    metadata: {}
      sone: 2
  - action: persistent_notification.create
      title: Test Alert
      message: "'{{avspillingsinfo}}'"
mode: single
Sorry, sorry, sorry, sorry! It was an indentation error in the recieving end, I thought it was in the sending end! :grimacing: I’m an idiot. I apologize so much!
So now it arrives but it arrives a bit messed up, so:
"Lørdagskveld i NRK P1: Du e så digg, Lyse Netter"
turns into
But I think that is in the receiving end, I can’t format it differently from the sending , can I?
I’m making an educated stab in the dark here, but it’s probably a URL encoding problem.
Try
      kommando: "{{avspillingsinfo|urlencode}}"
How would that look in the simple version? Like this? This still has the encoding error:
metadata: {}
  kommando: >
    {{ (state_attr('media_player.kjokken', 'media_title'|urlencode)) }}
  sone: 2
Close.
metadata: {}
  kommando: >
    {{ (state_attr('media_player.kjokken', 'media_title'))|urlencode }}
  sone: 2
Still same problem. I’m guessing it is on the receiving end, so I’m using string.gsub on the LUA system there in a script after receipt. Thank you very much for the help!
Edit: Before the script:
Lørdagskveld i NRK P1: Uten å si et ord, Frida Amundsen
After the script:
In your original example, this was missing the double {{ }} but that was sort of fixed by other things you tried. But it also explained why the variable wasn’t working.
Yep, that was discovered by @d921 during the process. :grin:
