Why should I use SSL on my MQTT (HA OS)
Hi there!
I have a quick question that bothers me for a while now and I can’t really find a suitable answer.
I’m using the official mosquito-broker add-on and mqtt integration. After searching through the forum and a few blog posts, I’ve found that everyone recommends enabling a secure mqtt connection.
So my question is: Is this really necessary?
As I understand it, the add-on runs as a docker container on the host machine in hassio. This makes it available through “core-mosquitto” and the mqtt integration auto detects it. It also using the homeassist user/password to connect to the broker.
Since this connection is local and not exposed, why would it matter to secure it with ssl if I don’t get access to this connection. Even if I use the Zigbee2mqtt add-on, it’s also connection with core-mosquito to the broker.
I understand that if I would like to access the broker from outside, this would be a necessary step. However, I don’t and don’t think I will in the future.
I used the MQTT Explorer and confirmed that I can connect to the mqtt broker with user/password on my local Host (mqtt://home.local:1883). But this is normally not something I would do.
Do I miss something here? Any help would be appreciated.
no
Well you know it is something that should be considered in my opinion.
For example roborock vacuums are using mqtt connection over port 8883 to talk to their servers. So mqtt over internet is using ssl.
Should you or anyone else be using ssl over local network? When I asked that question a few years ago everyone was ridiculed me as you know, look this stupid guy, ssl is used only over internet. But look at this. And this does rise some concerns.
I’m using ssl over local netwotk for access my ha ip and all other docker containers. And I’m considering using mqtt over ssl on local network and not just that.
They just said it was entirely local. For which SGs answer is fine.
Really?
I don’t think I’ve ever seen a post about it here.
No it isn’t.
Truth to be told you can use mqtt over insecure 1883 port in your own local network, but these isn’t secured.
Much better option would be to use it over ssl. Why?
Well, why most people are using seat belts when they drive their cars? Not because they seat in their cars with intention to crash it. In 99,9% of the time nothing will happen and you don’t actually need seat belt.
But there is always that 0,1 or less percent where is better to have it than not to have it.
And this is the same. If user can secure its mqtt communication over local network, then it is better to use it then not to use it. If he cannon’t well that doesn’t mean that its mqtt communication will be hacked or is insecure by default because intruder will have to gain access to it’s network. Gain access to someone else network with out owner permission is crime in most of the countries around the world.
To continue your analogy, seatbelts are fine for general motoring, a six point harness, fireproof suit and helmet are however complete overkill.
Having a properly secured witless network and only allowing trusted people to access your LAN it is sufficient for most use cases.
Having a properly secured local wifi is not that easy as it might seem. There are a lot of devices using wifi that can only use wpa2/psk and not wpa3.
Not mention all other things that ai brings with it.
So, something that was yesterday consider a secure doesn’t not mean that is secure today. Things are changing rapidly. And people should adopt to it.
Thinking that your lan is secure just because it is your lan is… well very optimistic.
And users should be aware of that.
