Wi-Fi IP camera supports ONVIF and doesn't require mobile app to setup
Looking for IP camera that
  1. Supports ONVIF, RTSP
  2. Doesn’t require a mobile app to setup
  3. No registration required with camera manufacturer
  4. Easy to integrate with HomeAssistant and NVR based on open source
Do you mean wifi or wired? If wired, then that’s pretty much any camera…
An example: I’ve just bought THIS mini camera on aliexpress and it works pretty much “out of the box”:
  • connect camera to power and LAN - usually has DHCP turned on so it get’s IP automatically
  • see in your router which IP has been assigned to camera
  • login to camera’s www page and change IP to static one; also change compression from h265 to h264 (or HA won’t be able to show picture)
  • add camera in HA (onvif integration)
  • you can also use addons like WebRTC - it can show rtsp stream
when setting up wifi cameras sometimes sadly you do need app, but just for initial setup, later it’s not needed anymore.
