After the latest update of HA my Raspberry Pi wouldn’t connect to my Wifi, so I started with a completely fresh install and it still won’t connect. I have used the create ‘my-network’ file method which has worked before for me. It will connect if I plug in the lan cable in. Any ideas
Do that.
Then if you absolutely must connect via wifi (I strongly advise against it) go to Supervisor / System and set up the wifi network in the Host card (press the Change button next to the IP address).
Thanks for the info, still not working as there seem to be a problem with my 2.4 Wifi as it doesn’t show in the list of access points.
What is there against connecting to wifi instead of lan cable?
A wired connection will always be more reliable.
