Wifi not connecting?
Hi all,
I simply cannot get my system to connect to wifi. Here is my file:
[connection]
id=resin-wifi
type=wifi
[wifi]
hidden=false
mode=infrastructure
ssid=XXXXX
[wifi-security]
auth-alg=open
key-mgmt=wpa-psk
psk=XXXXXXX
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
I have of course checked that my SSID and PSK is correct. Can anyone see what I’m doing wrong?
I have the same problem with a fresh install on my Pi Zero. I can’t get started because it does not connect to my WiFi.
Have you checked router for connected devices?
I read in another thread someone have problems because of wrong power supply, have you checked your power supply is big enough?
Try setting hidden=true if you have SSID broadcasting disabled. We don’t broadcast our SSID and this is was the one bit preventing my rpi from connecting to wifi.
I have the same problem with a fresh install on my Pi 3 B.
