I’m using a few older Audio Pro speakers which use a similar chip. Media images unfortunately never worked with this integration (I’m using it since the initial post)… My workaround is using the dlna integration for the image and a few custom sensors
I have been using this integration for about 4 months and it is very solid. Thank you for all your hard work!
Shuffle and Repeat doesn’t work when I’m playing stuff through the WiiM app with Spotify.
Doesn’t work with both Linkplay and the new WiiM integration on HA…
Anyone have a solution? (other than using Music Assistant… linkplay (spotify) presets load faster…)
I’m struggling to get the join and unjoin working properly from Music Assistant; it seems it’s happening at the Music Assistant level and therefore they don’t sync.
Can anyone share any insight on what I might be doing wrong?
I’m using the Arylic Up2Stream devices.
