Wildcard for sensor in automation
I did a automatoin which notifies me when a water sensor alerts.
I have various sensors in this automation. The message to my handy app is: message: Water sensor has triggert.
Now I want to know which sensor has triggert. Is it possible to put in a wildcard for the sensor in the message? For example: Water Sensor Office has triggert.
Yes, with templating you can do that:
- service: notify.notify
    message: "The {{ trigger.to_state.name }} has detected water"
Thank you for your reply.
Sorry, I´m new in Home Assistant.
I put this code to the configuration.yaml and what do I put in the "message: "?
It would help if you posted the automation that you have now.
Here you are
- id: '111'
  alias: Wassersensoren ausgelöst - notify
  description: ''
  - type: moist
    platform: device
    device_id:
    entity_id: binary_sensor.water_3
    domain: binary_sensor
  - type: moist
    platform: device
    device_id:
    entity_id: binary_sensor.wassersensor_wohnzimmer
  - type: moist
    platform: device
    device_id:
    entity_id: binary_sensor.wassersensor_kuche
  condition: []
  - service: notify.mobile_app
      message: "Wassersensor {{ trigger.to_state.name }} ausgelöst"
      title: Wassersensor
  mode: single
When the sensor has, I get the message without the sensor name (only: Wassersensor ausgelöst).
I suspect the problem is that you’re using device triggers, and the template values for triggers aren’t documented.
You could try moving to state triggers:
- id: '111'
  description: ''
  - platform: state
    to: 'on'
  - platform: state
    to: 'on'
  - platform: state
    to: 'on'
  condition: []
      title: Wassersensor
  mode: single
I changed it, but the sensor name still doesn’t appear…
Check your log file for errors, warnings, and other useful information.
It works now. I didn´t change anything. Thank you very much :+1:
I use it in diffrent automations. It works everywhere.
Only in one automation (Battery check) I get a error in the log: • Batterie check: Error executing script. Unexpected error for call_service at pos 1: Error rendering data template: UndefinedError: ‘trigger’ is undefined
Here the automation:
- id: 'xxx'
  alias: Batterie check
  description: ''
  - platform: state
    entity_id: sensor.fenster_xxx_battery_level
    to: '100'
  condition: []
      message: '{{ trigger.to_state.name }} Batterie fast leer'
  mode: single
The sensor “sensor.fenster_xxx_battery_level” has 100% battery. I use the “to: 100” trigger to receive a push message immediately when I start the automation.
What can be the problem?
The {{ trigger.to_state.name }} part only works when the automation is triggered by the trigger itself.
You cannot manually execute it, since doing so results in an undefined trigger.
Ah OK. Thank you for your post.
