Will Hardware Acceleration work with Frigate and Odroid N2+
Will Hardware Acceleration work with Frigate and Odroid N2+?
I’ve had to remove it and any parameters, otherwise ffmpeg crashes.
Here is my config file for frigate:
mqtt:
  host: 192.168.1.103
  client_id: frigate
  user: harry1
  password: *******
cameras:
  office:
    enabled: true
    ffmpeg:
      input_args:
        - -avoid_negative_ts
        - make_zero
        - -fflags
        - +genpts+discardcorrupt
        - -fflags
        - low_delay
        - -strict
        - experimental
        - -analyzeduration
        - 1000M
        - -probesize
        - 1000M
        - -rw_timeout
        - "5000000"
      inputs:
        - path: http://192.168.1.105/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=admin&password=*******
          input_args: preset-http-reolink
          roles:
            - record
        - path: http://192.168.1.105/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=admin&password=*******
          roles:
            - detect
        - path: rtsp://192.168.1.105/flv?port=8554&app=bcs&stream=channel0_main.bcs&user=admin&password=*******
          input_args: preset-rtsp-restream
          roles:
            - rtmp
detect:
  width: 640
  height: 480
  fps: 5
birdseye:
  enabled: true
record:
  enabled: true
  retain:
    days: 1
  events:
    retain:
      default: 2
      mode: all
      objects:
        person: 2
snapshots:
  enabled: true
  timestamp: true
  retain:
    default: 5
    objects:
      person: 5
you can get rid of this as it is doing nothing, the rtsp restream is the preferred method of restreaming and rtmp is deprecated
to answer your question, the Odroid does not have working hwaccel as far as I know, it definitely does not have a preset in frigate
