Hi there, I want to order all the things needed to start playing and experimenting with Home Assistant. I am preparing myself and wondering if the combined sensor of Qingping an be integrated? Here is the link, thank you all in advance for you help:
https://www.amazon.com/Thermometer-Hygrometer-Temperature-Notification-Rechargeable/dp/B0C6XWMRZ6
Hi, thank you for your quick reply. I am aware of this link, but I just have some doubts because the specific type I mentioned in the link above is not listed in the list of supported devices. Regards, Nils
Sorry to come back at this. So the device I want to connect is not listed in the list of built-in integrations, but the brand and several other devices are. Will this integration also will work with this sensor?
Thank you again for checking.
Anyone? Thanks…
Any idea if the products not mentioned in the list will be compatible? Thank you.
If they’re not mentioned, probably not.
The CO2 Temp RH (GCP22C) is listed.
