Hi all
I allready build DIY window blind controller. (NodeMCU, Mosfet, 2-4pcs strong servos)
Tested now controller couple days with Mqtt.fx send mqtt commands to controller and blinds works very well.
Now bigger question what i need to ask you experts. My mqtt “protocoll” works now very simple way.
- I send 2numbers to controller via mqtt.
- first number: is degrees how much blinds open. second number: is speed how fast servos drive.
- numbers scale is 0-9
Example if i send:
11 (Blinds open (1/9 degrees whole scale, and speed slowly 1)
91 (Blinds open totally 9/9, and speed are still 1)
99 (Blind open totally 9/9 and speed is fastest option 9)
Hopefully explained that good as i can with this english language skills
Now i want control that blinds via Home assistant.
- Maybe i can use slider both degrees and speed?
- I want couple “buttons” too what i can press and blinds go some degrees open, with something speed.
- I have zwave wall button what have 4buttons. Want to use that to open blinds and shutdown blinds.
- One extra thinking is can i do some 2other button do like this:
If i press upper button home assistant add that degrees number one every time when i click button. And when i click down button home assistant minus one number that degrees instruction. Then i can open and close blinds little bit of time with that zwave button. And after that i have that 2extra buttons what drive right away blinds totally open or totally closed?
Hope i explained my thinkings clearly. Of course if have some questions i try to answer them. I use normal Home assistant version. Allready thanks everyone who can help me with this project.
