Robiv8
(Robi)
1
Hello everyone,
Can someone explain to a newbie in HA how to teach my window or door contact so that it displays open/closed instead of off in the dashboard?
I tried searching but only found something from 2023. A lot has happened since then.
Thanks in advance.
Robert
Sensor: Zigbee 3.0
DoorWindowSensor
Model: ZD06
HomeAssistant: 2025.4.1 on Raspberry 5
Frontend: 20250404.0
Is the contact sensor a binary_sensor
If so you can change the Show As Here
Go to the entity settings in your dashboard. There’s a Show As option with a drop-down where you can select window or door
Edit: ninja’d by @LiQuid_cOOled
Too many sessions open on my end
Robiv8
(Robi)
5
Thank you both very much.
I’ll test it right away. It would be too easy if it were that simple
Robiv8
(Robi)
6
I’m amazed at how easy that was.
Thank you very much.
