I run HA in a docker container in a Ubuntu VM running in Hyper-V. I’m trying to use Bluetooth Beacons and I got a beacon setup that my phone can find, but I can’t get my server to see it.
I tried using “Bluetooth Beacon Interactor” from Windows Store but it says >>
Does anybody have any suggestions? Something I can enable in Windows or a way to use PowerShell maybe (probably ideal would be a powershell script that just continuously runs)
I was able to get this working via NirSoft’s BlueToothCL.exe and a powershell script to search for the MAC availability and post to a “WebHook_ID” to run my “Home” automation. This won’t work for “away”, but I have existing measures for that call and just wanted quicker/better home detection.
PowerShell script:
function Test-BTMacSearch {
param (
[String]
$MAC,
[int]
$TIMEOUT
IF (!$TIMEOUT) {$TIMEOUT = 15}
$searchresults = BlueToothCL -timeout $TIMEOUT | Select-String -Pattern $MAC
IF ($searchresults -ne $null) {return $TRUE} ELSE {return $FALSE}
$MAC = "##:##///"
$TIMEOUT = "10"
$WebHookURL= "https://freesoftwareservers.com/api/webhook/webook_id"
$BeaconMacFound = $False
WHILE ($BeaconMacFound -ne $TRUE) {
$BeaconMacFound = Test-BTMacSearch -MAC $MAC -TIMEOUT $TIMEOUT
Write-Host "BeaconMacFound = $BeaconMacFound"
If ($BeaconMacFound -eq $True) {
Write-Host "BeaconMacFound True Statement Running"
Invoke-WebRequest -Uri $WebHookURL -Method POST
sleep 1800 #Sleep 30 Minutes
$BeaconMacFound = $False #NeverEnding Loop $BeaconMacFound will always = $False at start of While Loop
See my blog for more details --> https://www.freesoftwareservers.com/display/FREES/Search+for+iBeacons+-+BLE+-+via+PowerShell+-+Home-Assistant+Presence+Detection+-+Windows
