WiNet extractor addon wont connect to my solar inverter
I need help to get my solar inverter and battery into home assistant
I tried about five different ways to do it and settled on this one
home-assistant-repo/winet-extractor at main · NickStallman/home-assistant-repo
Other are old, too complicated for my skill set using yaml or poorly documented.
The MQTT server is working as it provides details about my laptop. The iSolarCloud works on my iphone.
I have a Sungrow SH5.OR5 inverter and a Sungrow SBR096 battery.
Tried it with the Winet userid/password and without. I used my iSolarCloud uid/pwd as this was not clear in the instructions.
In the Addon for WiNet Extractor I go into the Configuration screen, restart and check the log which gives me the error below.
In case the ip address was wrong I checked every ip address on my network that was registered under Espressif. Same result each time.
Does anybody have a suggestion as to how I can get this working or am I doing something wrong
