I was able to successfully obtain the API key. I’m running into the following error when I run the script.
File "winix-02.py", line 41, in <module>
import paho.mqtt.client as mqtt
ModuleNotFoundError: No module named 'paho'
any ideas? I installed all the prereqs and I think I have the .yaml setup correctly… but I might be wrong.
probably my screw up. I am using this import to get MQTT support import paho.mqtt.client as mqtt
requires this install, which it looks like I am doing incorrectly in my ‘requirements.txt’ file…
pip3 install paho-mqtt
see if you can get paho-mqtt installed correctly and then try to run the program or launch python 3 from command prompt and look to see no errors from typing:
user@ubuntu-macmini2012:~$ python3
Python 3.8.5 (default, Jul 28 2020, 12:59:40)
[GCC 9.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
then exit python and try to run program. I am not the Python coder you want to follow
Good to see that you were successful with getting key and basic API for your unit.
OK so I got all the prereqs working properly and made some progress getting the script to run. Here’s the latest error:
File "winix-02.py", line 65, in <module>
handler_file = logging.handlers.RotatingFileHandler(WORKING_DIRECTORY + LOG_FILENAME, backupCount=5)
File "/usr/lib/python3.6/logging/handlers.py", line 150, in __init__
BaseRotatingHandler.__init__(self, filename, mode, encoding, delay)
File "/usr/lib/python3.6/logging/handlers.py", line 57, in __init__
logging.FileHandler.__init__(self, filename, mode, encoding, delay)
File "/usr/lib/python3.6/logging/__init__.py", line 1032, in __init__
StreamHandler.__init__(self, self._open())
File "/usr/lib/python3.6/logging/__init__.py", line 1061, in _open
return open(self.baseFilename, self.mode, encoding=self.encoding)
FileNotFoundError: [Errno 2] No such file or directory: '/mike/winix-public-main/winix-02.log'
Is there in issue with my .yaml file? Here’s that:
# DEBUG (and above)
# NOTSET (and above)
debug_level: "INFO"
# mqtt server IP address string
mqtt: "192.168.1.40"
# base topic for status and commands
mqtt_topic: "winix"
# put empty string for no remote logging
rsyslog: ""
# period in minutes between checking status of each unit
check_interval: 5
# winix units, important values are "key" and "mac_address", remainder are currently just informational
units:
"SB01" : {"home" : "My Home", "room" : "Bedroom", "key" : "XXXXXX_xxxxxx", "mac_address" : "XX:XX:XX:XX:XX:XX", "ip_address" : "192.168.1.XX"}
I’ve copied just the winix folder into custom_components, but the config.yaml changes I’ve made don’t recognize the component. I keep getting “Component error: winix - Integration ‘winix’ not found.” Anyone else having issues?
Restart HA regardless of the error. The GUI won’t restart because of the error, so I restarted my docker container instead. Once it started, it was working and detected.
After installing the custom WINIX component, install denysdovhan’s custom Purifier Card (it’s available in HACS by default). Here is the configuration I used to match the presets to the C545 modes:
I don’t mean to hijack the thread, but I’m very curious if anyone had any clues about this amazing plugin’s capabilities into Hubitat? I would be happy to collaborate! Thanks.
Thanks for posting your tips with regard to reboot and the Purifier Card. Worked like a charm!
One question: It seems as though I have full functionality, except I can’t toggle plasmawave on and off. The card reflects it’s state correctly, but I can’t turn it on and off from lovelace.
Any feedback on that? Maybe a better question for @leolite1
