This is the response I get:
{“data”:{“object_type”:“light_bulb”,“object_id”:“3616598”,“uuid”:“d4126d68-265b-4d41-b5c6-ded1fac1b957”,“created_at”:1525995100,“updated_at”:1526434167,“icon_id”:“66”,“icon_code”:“light_bulb-philips_hue”,“desired_state”:{},“last_reading”:{“connection”:true,“connection_updated_at”:1526434168.0145588,“powered”:false,“powered_updated_at”:1526434168.0145588,“brightness”:0.15,“brightness_updated_at”:1526434168.0145588,“desired_powered_updated_at”:1526434058.6853716,“desired_brightness_updated_at”:1526434058.6853716,“connection_changed_at”:1525995101.017664,“powered_changed_at”:1526434058.6222353,“brightness_changed_at”:1525998360.922579,“desired_powered_changed_at”:1526434058.6853716,“desired_brightness_changed_at”:1526434058.6853716},“subscription”:{“pubnub”:{“subscribe_key”:“sub-c-f7bf7f7e-0542-11e3-a5e8-02ee2ddab7fe”,“channel”:“af81cb228a7b04b27be9654b85116ae807c43c02|light_bulb-3616598|user-787233”}},“light_bulb_id”:“3616598”,“name”:“Light”,“locale”:null,“units”:{},“hidden_at”:null,“capabilities”:{“fields”:[{“type”:“boolean”,“field”:“connection”,“mutability”:“read-only”},{“type”:“boolean”,“field”:“powered”,“mutability”:“read-write”},{“type”:“percentage”,“field”:“brightness”,“mutability”:“read-write”}],“excludes_robot_cause”:true},“triggers”:,“manufacturer_device_model”:“philips_philips_hue_dimmable_light”,“manufacturer_device_id”:“00:17:88:b0:2a:d2_2”,“device_manufacturer”:“philips”,“model_name”:“Hue Dimmable Light”,“upc_id”:“479”,“upc_code”:“philips_hue_dimmable_light”,“primary_upc_code”:“philips_hue_dimmable_light”,“gang_id”:null,“hub_id”:“858204”,“local_id”:“2”,“radio_type”:null,“linked_service_id”:“1040982”,“lat_lng”:[null,null],“location”:null,“order”:0},“errors”:,“pagination”:{}}
The “desired_state” object is empty.
