Wink Component with Hub 2
Resolved: removed “refresh_token”
I followed the instructions for the wink component using “AUTHENTICATION WITH AN ACCESS TOKEN”, but it doesn’t work,
The result from the email/password web app was as followed:
“Put the following lines in your configuration file in the wink section”
access_token: !secret access_token
refresh_token: !secret refresh_token
MY CODE:
wink:
LOG ERROR:
17-04-03 13:36:07 INFO (MainThread) [homeassistant.loader] Loaded wink from homeassistant.components.wink
17-04-03 13:36:07 ERROR (MainThread) [homeassistant.config] Invalid config for [wink]: [refresh_token] is an invalid option for [wink]. Check: wink->wink->refresh_token. (See /home/homeassistant/.homeassistant/configuration.yaml, line 51). Please check the docs at https://home-assistant.io/components/wink/
17-04-03 13:36:07 ERROR (MainThread) [homeassistant.setup] Setup failed for wink: Invalid config.
Any ideas?
