Wink Developer Issues
When I try to use Wink via creating a developer account, I get an error stating “Client is not authorized or could not be found.” What steps should I take to get Wink working again, now that the username and password setup is no longer an option?
Make sure there are no leading/trailing spaces when you add the client ID and secret in the configurator
If you still have issues let me know what you are put into the callback URI sections and maybe provide a screenshot of the error.
That did it. There was a space before the client ID, which caused a %20 in the URL.
This https://github.com/home-assistant/home-assistant/pull/10317 should prevent this from happening going forward.
