WiPy micropython board
Anybody playing with the WiPy and home-assistant? Similar to the nodeMCU but uses micropython which for me is a big selling point
https://www.pycom.io/product/wipy-2-0/
There are two blog post about MicroPython on the ESP8266 development boards.
After the morning I’ve had with C on my particle, this looks like a dream.! https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/mqtt.html
I have a couple of nodemcu boards running micropython that I use to send temp/humidity/motion back to HA via mqtt.
Below is one that I use to monitor my homebrew:
 * The MIT License (MIT)
 * Copyright (c) 2017 Chris Smolen
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
import time
import dht
import machine
from umqtt.simple import MQTTClient
d = dht.DHT22(machine.Pin(5))
topic1 = b"YOUR_MQTT_TOPIC_1"
topic2 = b"YOUR_MQTT_TOPIC_2"
def MQTTpub(topic, data=None):
    try:
        client = MQTTClient(client_id="py_esp", server="YOUR_SERVER", user="YOUR_USERNAME",
                        password="YOUR_PASSWORD", port=1883)
        client.connect()
        client.publish(topic, data)
        sleep_ms(200)
        client.disconnect()
    except Exception as e:
        pass
def TempHum():
    try:
        d.measure()
        t = 9.0 / 5.0 * d.temperature() + 32
        h = d.humidity()
        return (t, h)
        return (-1, -1)
while True:
    print("starting while")
    (t, h) = TempHum()
    MQTTpub(topic1, str(t))
    MQTTpub(topic2, str(h))
    time.sleep(5)
Thanks @smolz that is significantly more elegant code that the C provided below.! Cheers
I am just recently getting into this. Do you have examples of more of your micro-python code? So far I have this but I am not really a programmer:
Yes checkout:
Do you have any examples with callback? I have implemented this so there isnt a delay when movement is detected via the PIR but not sure if there is a better way.
I haven’t yet, have you seen
https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/pir.html
Otherwise I recommend the pycom forum, very useful
