Wireguard addon not connecting
Hello all,
about a month ago i setup wireguard addon on my HA Yellow for my phone. After a bit troubleshooting it was working fine.
Tonight i wanted to add client for notebook as well but that caused everything to break.
yaml in addon :
server:
  host: <public HA address>
  addresses:
    - 172.27.66.1
  dns:
    - 1.1.1.1
  public_key: <HA addon public key>
  private_key: <HA addon private key>
peers:
  - name: phone
    public_key: <phone public key>
    addresses:
      - 172.27.66.2/32
    allowed_ips: []
    pre_shared_key: <phone preshared key>
    client_allowed_ips: []
  - name: notebook
    public_key: <notebook public key>
    addresses:
      - 172.27.66.3/32
    allowed_ips: []
    pre_shared_key: <notebook preshared key>
Addon does start and i am getting traffic
  allowed ips: 172.27.66.2/32
  transfer: 32.38 KiB received, 20.27 KiB sent
  persistent keepalive: every 25 seconds
However on the phone now i am getting rx: 0 and logs say error about failing handshake in 5s.
Can someone please point me in direction of how to get this to work?
To my understanding, the WireGuard Add-on doesn’t work like a traditional peer-to-peer WireGuard setup. It forces the HA machine to become a host/server, as can be seen in the yaml. I’m assuming this is by design for security to only allow a narrow tunnel to the HA machine, instead of actually creating a more robust WireGuard VPN. No other WireGuard compatible device works like that, that I’ve come across. I use WireGuard on my OpenWrt router, my phone, and my laptop, and they all use peer settings credentials. I’ve also heard/seen the add-on is quite fickle with devices and firmware.
That’s fine by me. My use case is e-2-e encryption of traffic for away devices. So 0.0.0.0/0 for allowed IPs and HA being server is my exact use case.
I am just puzzled why it doesn’t work suddenly when it was fine for couple weeks.
Did something change at the ISP level (What type of IP (NATing type)? Are you using dDNS (Dynamic DNS and FQDN)? Did you do any updates (HA, Home network)?
I was literally just going to mention that possibility, lol. Definitely! @koudy check your router/modem settings or investigate the port traffic with something like Wireshark. ISP’s are public enemy #1 with VPN’s and DNS providers.
This is rather strange. I took a break from phone settings and moved to notebook. It just works there. I connected to the mobile phone hotspot and enabled wireguard. Whatismyip was showing my public home IP address.
So after small break i went back to the phone just now and rebooted it. And now it works. I have no idea what happened there. Quote from IT crowd “Have you tried to turn it off and on again” comes to mind however… :man_facepalming:
I very much appreciate all the quick replies. Thank you very much for the help!
