Wireless connection of Elgato Stream Deck MK.2 to HA
I would like to control my Home Assistant devices/trigger HA automations by an Elgato Stream Deck MK.2 wirelessly.
Goal is something like this:
https://www.reddit.com/r/elgato/comments/1h6qpxx/wireless_stream_deck_a_dream_come_true/
First idea was: Connect Stream Deck to a Raspberry Pi Zero 2 W via USB cable. Glue Raspberry Pi Zero to Stream Deck. (Raspberry Pi can be powered via cable. I do not mind this.) From that “Stream Deck & Raspberry Pi”-Device trigger automations via WIFI by calling Webhooks provided by my Home Assistant (running locally on a Raspberry Pi 4).
Since I have not bought the Stream Deck yet and I cannot play around yet:
I believe that I do not get full advantage of the Stream Deck features, like displaying album art of the currently playing spotify song.
Question: Is there an easy way to connect the Stream Deck MK.2 wirelessly to the Raspberry Pi 4 (running Home Assistant) which makes the RPi4 “believe” that the connection originated from an USB-Cable?
Additional hardware plugged into Home Assistant Raspberry Pi 4 is an option. “Client” would be the Stream Deck, plugged into a “sending device” (RPi Zero W or dedicated “wireless sender” device).
