Withings integration needs a reload
I’m seeing an odd problem with the Withings integration in Home Assistant where the bed sensor works for, maybe, a few weeks, and then it stops reporting events. For instance, it reports the bed is occupied but then nothing.
Power cycling the device doesn’t fix it. If I reload the integration in Home Assistant it comes back to life. Has anyone else seen this, and is there a more appropriate forum to discuss this?
Is there a way to automate a reload of an integration if it stops reporting events after a certain time interval? Not an ideal solution, but it might be necessary in this case.
