I have been looking for a way to control the AudioReactive enable/disbale button in WLED (under the ‘Info’ tab) from Home Assistant for a while now, but cannot find it or work out a way using the current API’s.
This would be a great option to provide end users a button on a page to make the WLED lights be audio reactive or just a normal effects.
Would this be a viable option to add to either the entities that come into Home Assistant or add it to the WLED API?
Loaded up HA last evening on a Ubuntu machine. HA immediately highjacked my WLED device. While I can control my WLED device using HA for general lighting, my audio-rreactive feature is gone. I attempted to implement your ‘switch’ (above). The ‘switch’ does appear in my dashboard as ‘off’, but I cannot get it to switch to the ‘on’ position. Any additional guidance you can provide?
