I’m running into a sync issue between my WLED-based ESP32 grid matrix devices. Most settings sync fine (like brightness, colour & palette), but the ‘Expand 1D FX’ option under Segments doesn’t always stay consistent between devices (E.g.If the effect uses bar - The primary will be set as bar, but the secondary devices will be pixel). Has anyone else come across this issue? and if so have you been able to fix it?
Note: I have the following Receive settings Enabled;
